Old 07-03-2004, 03:16 PM   #1
67sss
67sss's Avatar
speedo stuff for 67cst
here you go. don't know if you need plastic gears, but here's a few I have in case you're changing your tire/wheel size.
67sss is offline   Reply With Quote
Old 07-03-2004, 04:14 PM   #2
67cst
i love summertime
67cst's Avatar
will that work with my th400?, im running 60 series tires but im not too concerned about the speedo being off a bit...im just heading out the door to go fishing for the afternoon, so ill get back to you tonight, but if that will work with my truck then im sure ill take it...
check pm
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 07-03-2004, 06:52 PM   #3
67sss
67sss's Avatar
350 or 400---tranny
does anybody know if the part where the speedo connects to the tranny differ on a turbo 350 to a turbo 400?
thanks.....
Old 07-04-2004, 04:10 AM   #4
67cst
i love summertime
67cst's Avatar
ttt-------------anyone?
Old 07-05-2004, 07:09 PM   #5
67cst
i love summertime
67cst's Avatar
one more bump! come on guys...someone must know if the speedo cables are the same on th350s and 400s...
thanks in advance
Old 07-05-2004, 11:13 PM   #6
Harold Shepard
speedo cables
Derek,
The cables are the same. The only problem I have seen is the variety of lengths in cables out there. Help! Product line of MotorMite offers several different cables but you need to know th approx. length of the one you have before hand. Any parts store should be able to get you a cable, but be sure to lube it good so that it does not rattle and twist. If you get some rubing alcohol and graphite power, create a solution and put it a spray bottle. The alcohol will act as the carrier for the graphite and the alcohol will evaporate leaving the graphite as the lube for the cable.
Harold Shepard is offline   Reply With Quote
Old 07-06-2004, 12:49 AM   #7
67cst
i love summertime
67cst's Avatar
thanks harold
