Old 07-04-2004, 01:20 AM   #1
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Anyone see this?
Got the transmission and transfer case put in today. Had to move the crossmember forward an inch and a half. Now the front drive shaft looks too long. I went from a 3 speed to a 4 speed and 221 transfer. Anyone had the same experience? Wondering if I'll have to have the drive shaft shortened. Rear shaft isn't in yet, so don't know if it will fit either. Thanks, Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 07-04-2004, 10:05 AM   #2
Yukon Jack
Post Whore
Yukon Jack's Avatar
I changed from a 3 speed to a 4 speed using the same 221 and didn't have to change anything or move the crossmember. The length difference is kept the same by changing the adapter length. Not sure why you had a difference. Did you stay with the 221 or was the 3 speed hooked to something else?
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 07-04-2004, 01:56 PM   #3
red71cheyenne
Back in the sticks
No the 3 speed had another transfer case on it. I got the 221 with the 4 speed from LeRoy. When I measured I thought they were the same, but like I said I had to shift forward about an Inch and a half. Guess I'll just have the front shaft shortened and hope the rear will work. If not I may have to have it lengthened. Have you had any trouble out of the 221? I have heard they are good, but not used this one yet. Jeff.
2011 K1500 Suburban
2014 K1500 Pickup
Old 07-04-2004, 05:25 PM   #4
1969 GMC
1969 GMC's Avatar
You probably had the 3 speed/dana 20 transfer case, which would explain why it was a different length. As for the Rockwell, the one that was in my truck served me well for 1 year. However, one of my output seals went bad and a slow drip started. I guess it grew overnight, and one day as I was driving it, it started to clank really bad. Took it out and discovered that all the bearings were shot, there were some balls floating around in the gear oil and the oil itself was a silver color from metalflakes. Also, the coupler sleeve between the tranny and transfer was almost completely worn smooth inside, and the tranny's rear output is toast.
I am still undergoing the everlasting NP205 swap now, i had to move the crossmember back about that length to make it fit.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 07-05-2004, 10:40 AM   #5
red71cheyenne
Back in the sticks
Hmm. Well, hope I don't have your luck. I did notice that the tranny output and transfer input do have some wear, but I didn't think it was too bad. Wonder how much it'll be to have them overhauled? Or if they can be. Whats so hard about the 205 swap? Other than the crossmember swap? Jeff.
2011 K1500 Suburban
2014 K1500 Pickup
Old 07-05-2004, 12:35 PM   #6
1969 GMC
1969 GMC's Avatar
The NP205 swap isn't hard at all, I just have not had time to work on my truck in a long time. I am not sure yet if the rear driveshaft will need changed, but im pretty sure the front is too long. Ok, I guess drilling the new holes in the frame was hard...but I used a DeWalt battery powered angle drill. Finding a 465/205 adaptor can be hard to do too, I was quoted around $200 for just the adaptor But a free 465/205 combo fell into my lap, so it was kinda nice.
1969 GMC K2500
1996 Honda Accord
Old 07-05-2004, 02:55 PM   #7
red71cheyenne
Back in the sticks
Congrats on that! Thats how the 465/221 was too. LeRoy had it out of one he was parting and let it go fairly cheap. Just hope it will last. Whats different about the 205? Does it not go right on the back of the 465? Guess not if you need an adaptor. Guess I will start pricing drive shaft mods. I'll have to cut the front down an inch or two and add an inch or two to the rear. Moving the crossmember wasn't hard on mine. Just moved forward 1.5 inches and drilled new holes. The hard part has been getting the shock mounts in to the transfer case.
2011 K1500 Suburban
2014 K1500 Pickup
Old 07-06-2004, 12:17 PM   #8
Yukon Jack
Post Whore
Yukon Jack's Avatar
No problems with the T221 in my 69 K20.
