Old 07-04-2004, 02:49 AM   #1
iluvmy72
Angry OT: Need help on Astro
I don't like to ask alot of these typs of things on here but I'm getting desparate. I have a 88 Astro Van that worked great up until 3 months ago when it would all of the suddn go into a high idle when in the park position and then stall on the road.....it started to lose power and stall all of the time and finally it wouldn't start back up one day. So I started to pull things off to take a look at what it could be. Turns out, I didn't see any gas coming out of the injectors on the cranking. So I replaced the fielfilter.....the old one was a little bad but I had seen worse.....still no fuel.....I can hear humming coming from the fuel pump so I know it's working.....or is it?.....also......when changing out the fuel filter, it leaked fuel on the flow side(bottom) and none on the top.
iluvmy72 is offline   Reply With Quote
