Resident Young Old Dude !
Gauges behind Bezel Install ( new Finished pics)
I have had a lot of E-mails and P.M's on how to do this, So here we go.
First Off,,,,, This was not my idea !!! Thor50 who is/was a member of this board had his dash set up this way. Well as we do, we said show me yours, and I'll show you mine!! I was extremely impressed with the looks of this set up.. As most of you know, I'm not into stock, But this took a Stock appearance but yet the dependability, accuracy, and Racy look of Autometer. So I put it on my "TO DO" list. I hadn't planned on doing it at this time, But a few weeks ago I found out that Autometer is/has "discontinued" this size (3-3/8") in their line of Gauges. Now I had to put it up front. All Gauges are Autometer, I don't know why another brand name wouldn't work as long as they are the same size as these. The Speedometer is a "In Dash" 5", The Tachometer is a 5" Monster tach. I see no reason another 5" Autometer wouldn't work, Like the ones with The Shift Lights and Memory Built In. The Center gauge is a 3-3/8" 5500 series. Like a 5505 for Oil Pressure, and a 5507 for a Water Temperature. I believe "if you can find one" the Fuel Level is 5514 for the 3-3/8" for G.M. The Lower Four Gauges are all 2-5/8" There are a numerous number of different gauges you can have your choice of. I chose, Fuel level, Fuel Pressure, Oil Pressure, and Volts. Let's get to the install. You will need to of course take the Gauge cluster totally apart. Seperate the stock gauges from the Mounting plates. Once everything is seperated, You'll need to remove some material from the Green inside metal piece, This piece is needed to Center and hold the 5" gauges in place. Not only remove metal from where the gauges go through it, But a piece all around the outside edge . This piece slides over the 5" gauges and is the main retainer. As far as the Larger 5" gauges go We get lucky here, They will "SLIP FIT" right into the holes that are there.. Very nice Surprise !!!! ![]() The next thing I did, And it's not absolutely necessary, I trimmed the Bezel on the outside of the round holes where the gauges slip over. This allows the gauges to seat down a little more and puts the face closer to the face of the Bezel IE: easier to see. There is also a Gussett that needs to be removed. This is the Gussett, ![]() This is the material I removed to seat the gauges better,Look at the upper outside edge, of the small hole. ![]() There is a lip on the outside of the 3-3/8" gauge, I trimmed some away from the hole opening of the center gauge to help this gauge center and remain there. ![]() Here's the lip on the Gauge I was talking about (the silver outer) ![]() Last edited by RON WOODGEARD; 07-04-2004 at 02:14 PM. |
Now you're ready to lay the gauges in. if you haven't opened up the openings in the green plate, you'll need to do it now. You will also have to remove some of the green piece where the lip was that rolled over the Bezel. This plate sits Over the larger gauges, and makes the edge stick out about 3/4" too much. I measured with a set of metal dividers the distance the piece was going to sip inside of the Outside metal retainer. And cut that amount off of the edge.( you'll see what I mean when you get here.) Just be sure to leave enough metal that when you Bolt the Outside piece on to the back, It seats down "TIGHT" against the outer edge of this green piece!!
![]() Next you will have to get the back metal plate ready to slip over the gauges. This piece is what will hold the gauges tight into place. There are plates that unbolt behind the Fuel Level Gauge, And the four small gauges at the bottom, ( or where 4 gauges can go) The back of where the speedometer went/goes and the part where the center gauge will go needs to be removed. This is a trial and fit step. And it depends on how neat you want the back to look, at how much time you're going to spend. I removed more then I needed to behind the speedo. ![]() The next step is to lay the back plate on and bolt it to the Bezel. ![]() ![]() Last edited by RON WOODGEARD; 07-04-2004 at 07:29 AM. |
Once the gauges are layed in place, and the rear plate is trimmed, You'll need to trim and drill holes in the small plates that bolt to the back. These plates are what actually hold the 4 gauges at the bottom in place.
![]() ![]() You'll also see how I mounted the center gauge, I used the Aluminum mount that came with the gauge. I straightened, and cut it shorter, drilled two holes in it to screw it to the back plate. Next is the Turn Signal "ARROWS" I cut the arrows out of the metal plate and reinstalled them like this....... ![]() ![]() Here's the final wiring on the Cluster itself. I threw some masking tape on each wire, and wrote what it's for. for quicker reference when the dash is being set back in.. Notice that an Autometer gauge light goes where the factory twist ones went. ( another nice Surprise!) ![]() And this is the Final finished project... At least on the bench. All that's needed now is to use a Multi-Meter to find the turn signals, and fuel level, at the plug which Used to plug into the back of the Cluster. I will cut these wires, and crimp ends on them to match the ends I installed on the wires coming off of the Cluster. I may post one more Picture of the cluster When it's installed. ![]() Last edited by RON WOODGEARD; 07-04-2004 at 02:19 PM. |
Good looking install....
Will you be adding the wiring to this thread or in a new thread...? Just a thought but this might be a good thread for the FAQ's
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
67-72 Addict!
Thanks for posting Ron, that's going to be sweet!. Can't wait for final pics!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
![]() Join Date: Apr 2000
How a bout a pic of the front.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
Who me?
Thanks for the info now I'm on the hunt for the fabled 3 3/8 gauge.
#8 | |
http://67-72chevytrucks.com/vboard/s....php3?t=110385 |
Looks great. Thanks for sharing your experience with the rest of us.
'01 Corvette Convertible, loaded, Vortex Ram Air, Corsa Pace Car Exhaust, TTS Powerloader II programming, JBA Shorty Headers '00 Heritage Softail Classic, Mikuni HSR42, Vance & Hines Straight Shots |
Send this to the FAQ section!!!! This definately needs to stay on the board! Great job, now to find those gauges.
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
Designated A-hole!
Hey Shawn didja ever find the pics for the filler door thread?
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
Designated A-hole!
A big thanks to Ron for writing and a big thanks to Josh for copying it to FAQ for us!
#13 |
Progress = 0%
Did you center the gauges in the bezel holes? The stock gauges were off centered (lower that the bezel holes) so when the cluster was installed and you were sitting in the truck looking down at the gauges, they appeared centered. When you look down at your gauges, the tops of the dial faces may appear "cut off" by the bezel. However, they may be located closer to the bezel than the stock ones so this may not be an issue. Just something to consider. I ran into this problem when I installed my Camaro tach. Otherwise, it looks great!
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
#14 |
67 is sold
Great thread - thanks
#15 |
Krue,
71swb4x4 just emailed the pics from when he saved the original thread. I will post them to the thread tonight. Shawn
