Old 07-04-2004, 08:39 AM   #1
FrankHoy
FrankHoy's Avatar
WTB Power Brake Booster Rod & hose
Anyone have an extra rod for a power brake that goes from the booster to the pedal arm. Also, would like to get the hose that goes from the booster to the carb base.
Have two of the Booster/MC setups and could have sworn I had the rods too. I went to install yesterday and can't find the rod now.
Would like to find both pieces but if necessary, I know I can get the hose piece from the local parts stores.
Thanks for any help.
72 Cheyenne 2wd LWB 402/350 CC/PS/PB/AC Tilt/Tach
(upgrading to 4X4 402/700R4 CC/PS/PB/AC Tilt/Tach PW/PL)
71 Custom Deluxe 350/350 Tilt/PS/PB
00 Blazer
FrankHoy is offline   Reply With Quote
Old 07-04-2004, 04:04 PM   #2
billsbowtie
billsbowtie's Avatar
is this the one you need in lower right hand of pic. thanks
billsbowtie is offline   Reply With Quote
Old 07-13-2004, 08:23 PM   #3
FrankHoy
FrankHoy's Avatar
I am still in need of the brake pedal rod. Anyone help!!! Do any of the vendors have these?
00 Blazer
Old 07-13-2004, 08:29 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You need the linkage too. Notice the bellcrank that pivots between the rod and the booster rod.
Old 07-13-2004, 09:13 PM   #5
FrankHoy
FrankHoy's Avatar
I have circled what I need. I have everything else. I just need the rod from the booster pivot arm (or ? whatever it is called) and the pin & clip that secures the rod.
By showing me your picture are you inferring yours is for sale? Or are you just being nice & using it to show the various parts?
00 Blazer
Old 07-13-2004, 09:16 PM   #6
Tx Firefighter
Sorry man, my 454 truck really needs those power brakes. I'm buying a new booster this week as a matter of fact. I just took a pile of pictures of it before I tore it apart to detail all the pieces with POR15 paint.
Old 07-13-2004, 09:19 PM   #7
pickupman
pickupman's Avatar
Frankhoy, if you still need the rod, I know I have some of those. Do you need the metal portion of the hose that goes into carb or the rubber hose. I may have the metal. Will have to wait till I get back at the shop. Just let me know.
atheystruck@comcast.net
67 1/2 ton 4wd custom cab
72 1/2 ton 4wd super cheyenne
71 1/2 BB super cheyenne shortbed
pickupman is offline   Reply With Quote
Old 07-13-2004, 09:20 PM   #8
chevytruckfan
chevytruckfan's Avatar
Billsbowtie,
Are those taillight trim rings chorme? If so how much do you want for them?
chevytruckfan is offline   Reply With Quote
Old 07-13-2004, 09:26 PM   #9
FrankHoy
FrankHoy's Avatar
Tx Firefighter- Understand, can't fault a guy for trying, can ya?
Anyone have an interchange manual, or can say what years & vehicles share the same rod? I would think this is fairly common setup. Seems my 65 Impala had the same or very similar booster setup.
I have a 67-78 Chevrolet pickup interchange manual and can't find the rod in it, for any years.
pickupman - Yes, I can use the Rod, Pin & clip, full hose and ends from booster to carb base. The rod is the most important, as I know I can get the rest locally new. But if you have it all, it would be easier to have one-stop shopping.
00 Blazer
Old 07-13-2004, 10:04 PM   #10
pickupman
pickupman's Avatar
I will check to see what I have tomorrow for you
Old 07-13-2004, 10:21 PM   #11
neonlarry
neonlarry's Avatar
I think I have one, if you still need it I can chack.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 07-14-2004, 01:59 PM   #12
pickupman
pickupman's Avatar
I did have the rod and metal portion of the hose. Could not find the pin and clip. If interested, $18 shipped to you.
Thanks, Bill
Old 07-14-2004, 02:23 PM   #13
FrankHoy
FrankHoy's Avatar
Pickupman - PM sent.
neonlarry - Thanks - I will buy Pickupman since he offered first. You by chance have the pin he doesn't have?
00 Blazer
