Old 07-04-2004, 07:27 PM   #1
pritch
pritch's Avatar
I Found a parts donor Burb, a few ???
I want to get started of a frame for my '68 panel. I found a '68 Burb that I can get fairly cheap, but it's a 3/4 ton and my panel is 1/2. Are the two frames the same? I'd like to stay with 1/2 for the ride, plus, call me crazy but I like the 6 lug look. This Burb has a v-8/automatic, so I can use the mounts and x-member and the front clip and bumpers are in pretty good shape.
pritch is offline   Reply With Quote
Old 07-05-2004, 11:44 PM   #2
Rod
Pretty much the difference between 3/4 and 1/2 ton 2wd are the rubber body bushing and rad cradle bushing are bigger on the 3/4 ton suspension vehicles. The rear cab mount on the frame is at a lower height on the frame of the 3/4 ton but its lift is achived by the longer cab bushings.. so the 3/4 sits as little higher. Hmm but this is a sub right... hmm dont have a 2wd sub but thats the way it is with trucks... should be the same for subs possibly.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 07-06-2004, 11:43 AM   #3
sbrban
Only difference on 'burb frames is the suspension - the frame itself is the same.
you never have too many suburbans....
sbrban is offline   Reply With Quote
