Old 07-04-2004, 11:28 PM   #1
1986Silverado
What I drive
1986Silverado's Avatar
Speedometer ?
Well got the tranny in today and got it running. Installed a new speedo cable cause the old one was broke and previous owner had disconnected it and filled the gear in the tranny with silicone. Anyway....I removed the silicone, installed the cable and all seemed well until I drove it. The cable makes a clicking noise and is consistent and the needle in the guage kinda bounces back and forth and all the way around. The needle also does the bounce or jump at the same time the click is heard Could this be the speedo gear in the tranny? I think it is rounded out but still catching the cable when the click is heard. I also think it is the gear because when I installed the new cable it fell into place to easy.
1986 Chevy Crew Cab Dually(Choo-Choo Conversion)
2006 Chevy Equinox
1986Silverado is offline   Reply With Quote
Old 07-05-2004, 09:44 AM   #2
SanitysBane
nope, its the speedmoiter itself, our 88 van did that.
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 07-05-2004, 05:13 PM   #3
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
It could be the cable housing or the gauge itself. What part is rounded out? That could be causing the jumping and might eliminate the other two ideas.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 07-05-2004, 08:43 PM   #4
NeCrOmAnCeR
NeCrOmAnCeR's Avatar
You might try to spin the cable down by the tranny to see if the speedo bounces with the drill driving it. Would also allow you to track down the clicking if it still does.
NeCrOmAnCeR is offline   Reply With Quote
Old 07-06-2004, 12:17 PM   #5
1986Silverado
What I drive
I think the speedo gear in the tranny is rounded out. The clicking noise is coming from the guage so the guage may be the problem. I had the dash apart acouple of weeks ago and had the speedo guage out and the part that holds the gears in that spins the odometer numbers was broke and the little pin that holds those gears was moving around, up and down. It was really sloppy.
2006 Chevy Equinox
Old 07-07-2004, 01:37 PM   #6
1986Silverado
What I drive
The speedo is bad. I took the cable loose from the tranny and hooked a drill to it and it is clicking and bouncing with the drill. I also had to get the cable just right to go back into the tranny gear so it must be ok.
2006 Chevy Equinox
Old 07-07-2004, 01:38 PM   #7
ocbaud
Garage Queen Material
haha when i looked at this title i read : "speed-o-meter"
haha
ocbaud is offline   Reply With Quote
