Alright Alright Alright
looking for a posi
i have a 72 cheyenne that despratly needs a 12 bolt truck posi. i see them for 300 dollars from eaton. im looking for one of any year for a reasonable price if anyone has one.
1972 Cheyenne Chevrolet red and white 357ci, Vortec heads, GM Performance high rise intake, Comp 268H .454/.454 218/218 110 LSA Quadrajet carb, Flowtech headers, 2.25 40 series HEI, Curve kit, TH 350, 3.07 gears 275/60/15s on 15x8 rallies |
What size gears are you wanting with the posi ? Jose
i have a 3.07 right now but i plan to go with a 3.42 ratio. so i guess i will need the 3.07-3.42 3 series unit
I do have a 12 bolt posi with the 307 gears . I do want to keep them together 200.00 plus shipping . Jose
it might take a while to come up with. i do think its a great off and i will get back to you
A splendid one to behold
sorry about the OT, but is that $300 you speak of from eaton, brand new? sounds cheap.
67 swb 02 wrx |
well i see alot of them on ebay brand new for 300+
im looking for a used posi that is out of any trucks that are compatible
sent you a PM I have a one I am not sure what year truck it is from I will look at it tonight to see the markings on it. It is a 12 bolt truck series 3. I bought it a year or so and never installed it, my plans (as usual) have changed. I will take 100 dollars plus shipping. I got it from a guy on the board so I dont know much history on it.
Thanks Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
Just Don't Stop!
![]() Join Date: Feb 2004
Custom 68, if it will fit 3.73's I'll take it if he doesn't...
1968 C10 build in process TT LSA/6L90e/9" |
3.73 is a 4 series isnt it?
yes it requires a series 4 so it will not fit the standard 3.73, it will however fit the "thick" aftermarket 3.73 gear set.
crm318 I have responded to you PM. I will mark it as sold I will get you the shipping weight and have it ready to go. Thanks Dave
#13 |
i'm confused. so you are saying a stock 3.73 gear has to be used with a 4 series carrier, but you can use an aftermarket 3.73 in a 3 series?
67 swb 02 wrx |
#14 | |
Vortec in the works
68? It's all figured out untill you get it apart. Is it Sunday yet??? 68 Project 68 SWB frame off/98 Vortec with stock FI/power everything. 95 ECLB 2500 with 346,000 on the clock(the original HD) 99 Lesabre-wifes ride 08 Crew Cab LTZ-All Mine 89 SWB 5/7 drop-Son's first ride. |
#15 | |
If this link works it lists a 3.73 gear set for the series 3 carrier. This is a special gear again my understanding is that it has a thicker ring gear to space it properly. I have seen them referenced in different catalogs (Summit) Somebody else chime in with any more info or to set me straight? But yes the stock 3.73 will not work with this series. Dave
