Old 07-05-2004, 02:56 PM   #1
dbowyer76k5
Exclamation Fuel gage pegs out
I picked up this K-5 a few months ago. With the ignition off, the gage reads a little over full. Turn the ignition on and it pegs out way past full. I found one tan wire going to the sending unit and checked the voltage and there is none. I'm stumped........
dbowyer76k5 is offline   Reply With Quote
Old 07-05-2004, 05:04 PM   #2
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
I would check the all the grounds and clean them up and make sure they get good contact.
Welcome to the board
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 07-05-2004, 10:54 PM   #3
bagged74
its just $$$$$
bagged74's Avatar
Either the wire is grounded out somewhere or the sending unit is bad. check it with an ohm meter to see if it is grounded out.
bagged74 is offline   Reply With Quote
Old 07-05-2004, 11:44 PM   #4
NeCrOmAnCeR
NeCrOmAnCeR's Avatar
I have to agree with mylilbowtie, the guage will read high with a bad ground, loose connection. If the wire was shorted to ground, the gauge will read empty.
NeCrOmAnCeR is offline   Reply With Quote
Old 07-11-2004, 01:48 AM   #5
nn2004
What should the ohm meter usually read when it is full? And empty?
1987 Chevrolet R10 Custom Deluxe
Stock 350, TH350, 3.42 Rear
nn2004 is offline   Reply With Quote
Old 07-11-2004, 09:30 AM   #6
SanitysBane
0 empty 90 full
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
