Old 07-05-2004, 06:06 PM   #1
bigunde
Rusty Rockerfeller
changing the front grill area
What all does it take to change a 90 cheyenne front end to the composite headlight front end?thanks
bigunde is offline   Reply With Quote
Old 07-05-2004, 08:19 PM   #2
autopainter13
autopainter13's Avatar
do you mean like on a 94? im pretty sure just the headlights and grill and other lights. worst case senario is tapping a few holes in the core support to mount the new stuff. if you need any composite lights check out my post in the parts form
autopainter13 is offline   Reply With Quote
Old 07-05-2004, 08:20 PM   #3
bigunde
Rusty Rockerfeller
good deal,ill check it out.someone said you had to change the core support too.i hope not and thanks again
Old 07-05-2004, 08:32 PM   #4
autopainter13
ill check at work tomorrow to see if the core supports are the same or if you have to change them. ill PM you with the info tomorrow night
Old 07-05-2004, 08:38 PM   #5
bigunde
Rusty Rockerfeller
good deal and thanks
Old 07-06-2004, 08:26 PM   #6
autopainter13
core support is the same
Old 07-07-2004, 01:11 PM   #7
jrcmedic
I want to do the same with my 92 GMC. I'm pretty sure that the wiring is going to have to change so I can use bulbs in place of the sealed beams, and of course the grill. Let me know how you make out and what it runs you dollar wise.
jrcmedic is offline   Reply With Quote
Old 07-07-2004, 02:00 PM   #8
99-2door
99-2door's Avatar
Yeah you really need a harness from a similar year composite truck. I see them on ebay occasionally. The core supports are the same. Would be nice to upgrade to 94-98 style grill while you are at it.
95 K3500 SRW 5.7L Vortec 4L80e 4.10 G80
2001 GMC C3 6.0 AWD, Volant, 3/5 drop TBSS intake, HP tuners, pullies, 05 efans, 05 front brakes, etc.
2003 Tahoe Z71 Silverado front clip
99-2door is offline   Reply With Quote
Old 07-07-2004, 03:56 PM   #9
Kybol
Kybol's Avatar
It's not to bad, I did it to my 90. Just need the lights and holders, corner lenses, grille, and grilel filler. Not to sure of what else. But I went from a silverado grille to the new style.
-90 454ss http://www.imagestation.com/album/?id=4289115843
-04 TRX450R
-77 c-10 http://www.imagestation.com/album/?id=4290506213 SOLD
-82 c-10 SOLD
-02 CRF450 SOLD
Kybol is offline   Reply With Quote
Old 07-08-2004, 10:07 PM   #10
jrcmedic
I caught an ad in one of the truck rags that offer the whole kit including the pig tails for about 500. I left it at work so I'll get the supplier name in a day or two.
Old 07-09-2004, 12:47 AM   #11
Quagmire
A splendid one to behold
Quagmire's Avatar
very common swap. once you find out all the parts needed, check with your local gm dealer as you may be able to get them cheaper there.
iirc, you will need the headlights, turn signal lights, reflectors, grill shell, two corner pieces that go in between the grill and the bumper (on each side) and the vallence piece that goes between the grill and the bumper across the front.
67 swb
02 wrx
Quagmire is offline   Reply With Quote
Old 07-18-2004, 08:55 PM   #12
jrcmedic
OK, as I said I got the ad now. The supplier of the whole kit to change to the newer style is JBM sport truck accessories. 800-598-5555. it looks to run about 550 for the whole shabang. I'm going to get it and I'll let you all know the results after it's done.
