Old 07-05-2004, 08:23 PM   #1
special70gmc
special70gmc's Avatar
38x15.5 super swamper tsl
can i fit these on my truck? i got a 6in susp lift and 2 in body lift. right now its got 35x12.5 on it and i personally think there way too small also i was thinking of painting it black like my 70 but maybe orange again. thanks - kyle
1986 c-10 swb 5/7 drop 20'' coys
1958 belair 2door
special70gmc is offline   Reply With Quote
Old 07-05-2004, 09:24 PM   #2
Mudder
Mudder's Avatar
Ok go out and look at your tires and wheel wells.........38's will be 1 1/2 inch bigger all the way around and they will be wider.
Mudder is offline   Reply With Quote
Old 07-05-2004, 10:16 PM   #3
drink2mny
drink2mny's Avatar
I run 38's when playing around
I have 6 1/2" suspension and 2" body
You will hit your front fenders twisting and turning into a hole or rut
but I have never bent or damaged the fender just the chrome trim
Support The Board
drink2mny is offline   Reply With Quote
Old 07-05-2004, 11:08 PM   #4
LONGHAIR
It depends on your intended use. If you are just street driving they will be fine. If you are into heavier off-roading, especially on extreme turns and bumps they will probably rub the back corner of the fenders. The off-set of the wheels will have some affect too.
LONGHAIR is offline   Reply With Quote
Old 07-05-2004, 11:33 PM   #5
1FaastC10
1FaastC10's Avatar
yup, these are 38.5 TSLs with 6" suspension, 3" body lift. body lift has since been removed and fenders hacked. i'll be running 38.5s or 39.5s on mine with under 6" of lift.
1FaastC10 is offline   Reply With Quote
