turbo enthusiast
how can you tell......
I'm in the market to buy a "real" 2 wheel drive blazer/jimmy. With all the people out there converting 4x4's to 2wd, how can I tell if the truck was originally a 2wd from the factory? Thanks in advance.
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting ![]() |
SKINNY TIRES RULE!
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
factory 2wd's have coil springs on the rear. if you find one with leaf springs it used to be a 4wd.
74 swb 71 2wd Jimmy 82 2wd Blazer |
You can also check the numbers on the frame by the drivers side exhaust manifold and make sure they match up to the vin and add to that the fact that they only come with coils on the rear.
On mine they did not change the lower radiator supports that is also used for the front leafs. May check it and look for bolts instead of rivets, would be another clue.
Just wondering. I have seen several GMC truck with leaf rears, any chance that a 2WD GMC Jimmy could have the leafs in the rear?
1972 C10 SWB 350 / T400 1972 SWB GMC 350/T350 1972 Cheyenne 20 super "long horn". 402BB / T400 1972 Suburban C10 Deluxe 350 / T350 and a few more.. http://www.myspace.com/afew72s |
![]() Join Date: Jun 2002
Some guys go through the trouble to put the trailing arms in but the frame rails above the rear end of a 4x4 are straight and the frame rails on a 2wd bow out slightly.
If you are going stock, I'd look for an original, but if you want to lower or modify, I wouldn't worry about it too much. The real 2wd are hard to find, and they are all cool.
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
few 72's, the jimmies have trailing arms also, not leaf springs.
Rg
one thing people dont change is where the 4x4 shifter comes through the floor.
were there actually any 2wd stick shifts? i have never heard of one or seen one! |
Stick Shift 2WD
Green 72 here in Roanoke, Va. 350,4bbl, 4 speed w/ granny gear. Wish I would have been there a day earlier!!!!!!!!! moodyholler
1998 WRANGLER I-6 auto 1972 LWB FLEETSIDE 1968 GMC SWB STEPSIDE 1994 C-1500 SWB 4.3 5 SPD |
I saw a BEAUTIFUL 71 orange blazer this weekend at a car show that had leafs in the rear. The guy swore it was original but I always thought Blazers had trailing arms. His doors were shut so I never saw the vin.
Maybe I've been wrong all these years...
SKINNY TIRES RULE!
I doubt that was original if it had leafs. Someone probably pulled a fast one on the owner and he is convinced it is original.
It ain't right what people will do for money... I don't mind conversions as long as people are honest about it.
