Old 07-06-2004, 10:04 AM   #1
n737nc
Question about harmonic balancers...
Still green, getting the stupid questions out of the way.
If you have one size balancer, do you have to stay with that same size?
Reason that I am asking is I have a larger balancer on my motor(7.5inch). But, the balancer is too narow that the timing tab covers it up(picture). So, when I time the motor, I have to time it to 16, then guess from there.
Can I change my balancer to a smaller one? If so, what size do I need?
Thanks,
Nick
n737nc is offline   Reply With Quote
Old 07-06-2004, 10:41 AM   #2
walker
walker's Avatar
I would just go down and get a different timing tab, or trim/bend the one you have to fit. You could also mark the front of the balancer with white paint where the timing mark is.
Andy,Phx AZ
'67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...)
"23 C-Cab-sold
'48 Ford 8N tractor(still working)
'67 Scout(Now on the road)
'70 MG B.-sold
walker is offline   Reply With Quote
Old 07-06-2004, 10:43 AM   #3
JimKshortstep4x4
Smile
You can change the balancer if it is an internally balanced engine, but what I would do is paint a white line on the front of the balancer. Just extend a line from the groove that is in the balancer.
The timing light will pick it up and you will be able to see the mark.
I don't understand what has created your situation. It looks like the pointer is the wrong one because the face of the balancer is in the right location.
Jim
Old 07-06-2004, 11:22 AM   #4
Putter
More Cowbell....
Putter's Avatar
Is that a chrome timing cover? I think I see a reflection...that might explain why the timing tab is longer. Just a thought.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 07-06-2004, 11:58 AM   #5
n737nc
Thanks for the replies.
Yes it is a chrome timing cover. That is getting ready to change though. I have been having a problem with the front main seal leaking between the timing cover and the oil pan. So, I bought a new pan and timing cover. Going to pull the motor out this week to replace them(along with some other parts).
I thought that the balancer was wrong because it seems to run better when it is more advaced(more towards the top of the balancer). I was thinking that the timing tab should be at the top of the timing cover, instead of on the side. But with my short water pump, there would be no way to see the timing tab if it was moved up there.
Is the timing mark in a different location with the different size balancers?
Thanks for everyones help.
Nick
Old 07-06-2004, 12:17 PM   #6
JimKshortstep4x4
Smile
Some of the newer engines have the timing tab on top as you were suggesting but the 67-72 truck engines have the timing as your picture.
The other possibilities are that the outer ring on the balancer has slipped or that you are setting the timing with the vacuum advance hooked up.
Jim
Old 07-06-2004, 12:40 PM   #7
Fred T
Cantankerous Geezer
Fred T's Avatar
On your oil leak. Check the shaft on the balancer. If there is a groove worn where the seal is, you need to either put a redi-sleeve on the shaft or replace the balancer. I would suggest a new balancer. The rubber is old and worn, quite possibly has slipped. If your engine is not externally balanced (400 ci) you can go up or down on the balancer size. Also, I would replace the timing tab at the same time.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 07-07-2004, 07:10 PM   #8
willow72
willow72's Avatar
you could just clean the balancer you have off real good and go too your nearest performance parts store or jegs.com and order a timing tape for your size balancer and stick it on
willow72 is offline   Reply With Quote
Old 07-07-2004, 07:41 PM   #9
Quagmire
A splendid one to behold
Quagmire's Avatar
ditto. very helpful piece and not much dough
67 swb
02 wrx
Quagmire is offline   Reply With Quote
Old 07-08-2004, 09:02 AM   #10
bigjimzlll
bigjimzlll's Avatar
I have never had any luck with the tape sticking(and staying) Proform makes a balancer cover that is a nice and cheap piece. I always take and mark a line on the front of the balancer..from the outside ring to the inside ring..that way you can see if the outside ring slips
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 07-08-2004, 05:15 PM   #11
willow72
willow72's Avatar
yea i forgot about those they are about 30$ aint they? are they hard to put on?
Old 07-08-2004, 10:53 PM   #12
72C203503ONTHETREE
72C203503ONTHETREE's Avatar
Chevy used two different balancer with different timing marks located differently compared to the keyway. All will work on your engine(if you have anything other than a 400 sb), just your timing marker may not be in the right position anymore. Chevies high performance balancers were mostly 8 inchers while normal sizes were 6-7 inches. I never use a timing light to time an engine, I just advance the timing just until it starts to ping and then back it off a tiny bit. Gets the best power and mileage that way since it maximizes the engines potential to make power.
72 Chevy C20, SOLD (Dang it.)
09 Challanger RT six speed in all black.
74 Datsun 710 wagon, all 1.8 liters of screaming Datsun power.
73 C10 long bed, 350/350 combo, nice shape.
72C203503ONTHETREE is offline   Reply With Quote
Old 07-08-2004, 11:54 PM   #13
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
http://www.chevyhiperformance.com/te...402/index.html
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 07-09-2004, 02:00 PM   #14
Blue68
Blue68's Avatar
This is one of those things that if you're going to have it off, and it's original, replace it while you're there. The rubber/elastomer does wear out and won't control the harmonics as well as a new one. If the tab isn't part of the cover, just replace it with a shorter tab.
If it weren't for the leak, I'd say stick with the white paint stripe. Works wonders under a timing light.
http://home.comcast.net/~r.landrum/w...tos.html-.html
'68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades.
Blue68 is offline   Reply With Quote
