07-06-2004, 05:08 PM | #1 |
spring rates
Any know now that the front spring rate would be for a 1/2 long box truck that came with a 305 and light duty brakes? or the part number for the front springs.
thanks
'96 Nissan Pathfinder '02 Firebird Trans Am. '88 K5 Blazer |
07-06-2004, 05:35 PM | #2 |
Right turn Clyde
Stock front coil springs for an 83 1/2 ton, Moog-6452 / TRW-CS6452. If you want Heavy duty springs they are Moog-6454 / TRW-CS6454
With the 454 installed I would use the Heavy duty springs. Stock springs for a 305 will lower it a couple of inches with the 454 in it.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI Last edited by MylilBowTie; 07-06-2004 at 05:38 PM. |
07-06-2004, 10:39 PM | #3 |
i need the spring rate, like 200 lbs/inch or what ever it is
07-07-2004, 12:14 AM | #4 |
thanks for the post mylilbowtie, i think i may go see if i can mesure one at the parts store
