Old 07-07-2004, 12:56 PM   #1
87Silvy
87Silvy's Avatar
Talking Need Opinion on Engine Selection
Tell me what ya'll think..........
http://www.paceparts.com/index.asp?P...D&ProdID=83801
1987 Chevrolet Silverado
2005 Chevrolet Silverado
87Silvy is offline   Reply With Quote
Old 07-07-2004, 01:12 PM   #2
PHOENIX
I think you could do a lot better for a lot less money.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 07-07-2004, 04:35 PM   #3
87Silvy
87Silvy's Avatar
I agree with that, but I want something that no one else has in an 81-87 Chevy, and it has to be fuel injected. The LS1 that comes stock in the Camaros is actually higher in price that that one is, plus you don't get everything with it. The one I posted above comes with everything minus the ECM and wiring harness.
Old 07-07-2004, 04:44 PM   #4
Izzy
Trucker.
Izzy's Avatar
The harness to go into your truck is going to run you about $750-850 and the ECM is going to run about $250-350 with a custom tune for that truck. Those are the prices I was given to put a 99-04 LM7 into my 83. IMO I'd agree you could get a better motor or get a pull out from camaro/vette for less with an ecm/harness and save yourself some $$.
Izzy is offline   Reply With Quote
Old 07-07-2004, 04:51 PM   #5
PHOENIX
Do you plan on finding some ways to incorporate some of the 2004 GTO features into your truck?
Old 07-07-2004, 04:56 PM   #6
87Silvy
87Silvy's Avatar
No, not really. Just found the engine while searching, saw that it was cheaper that the regular LS1. I do plan on putting a Richmond 6-speed behind it though.
I'll prolly just have the 350 rebuilt for now. I want to find something that will get good gas mileage and have good power. I know, I am asking a lot.
Old 07-07-2004, 05:35 PM   #7
PHOENIX
As far as 6-speed's go you might want to consider this one:
This one will put the shifter in the original location so it does not interfere with the seat or center console.
http://www.standardtransmission.com/BW_T-56.html
1386-000-011MS
Aftermarket GM
w/ shifter modified for 4sp replacement application
$2575.00
Standard Transmission & Gear Co.
1000 N.E. 29th
Fort Worth, TX 76106
Local: (817) 625-7109
Toll Free: 800-783-8726
Fax: (817) 625-0580
EDIT:
The Richmond only has one overdrive, while the T-56 above has two.
So it depends on which you would prefer. If you plan to drive at highway speeds often you may want the two overdrives, if you are more for hotrodding around town with some highway driving the Richmond 6 would suit you fine too. I believe the 4-speed shifter location is something to really consider.
