07-07-2004, 06:15 PM | #1 |
easy weatherstripping
a friend of mine just told me that the door opening weatherstriping out of a 82-93 s10 truck will clip right into our 67/72 chevy trucks with no glue. has anybody heard of this or done this if so did it work?
07-07-2004, 06:58 PM | #2 |
Sounds like a good time saver not having to screw around with weatherstrip adhesive.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
07-07-2004, 07:03 PM | #3 |
Yes I heard of it working but arent those doors smaller than ours?
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
07-07-2004, 07:17 PM | #4 |
Check out this post:
http://67-72chevytrucks.com/vboard/s...threadid=72369
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
07-07-2004, 07:36 PM | #5 |
A splendid one to behold
good news. i was just contemplating buying more adhesive to re-do my doors
for all the bs and hassle, i think i will fork out the extra dough and try the s10 seals next time
67 swb 02 wrx |
07-08-2004, 03:19 AM | #6 |
i used seals off a 88-90 something chevy truck, got them off ebay for 15 dollars new, fit great and actually had to trim them because they were to long. the only problem is the door on these trucks have a sharp corner where as the newer ones are rounded, i cut mine at an angle to make this corner.
07-08-2004, 07:59 AM | #7 |
I will get another pic of the mitered corner put up today. It must have been lost in the board change over, and I didn't save it either. They have been on my 71 for almost a year now, no problems. I highly recommend them. And once they are on you won't have to think about them again. If you need to paint the truck, you'll work at it but pull the seals off and push them back on. Our S10 seals come like the original seals, cut to fit, both measure about the same length.
71 Chevy CST Long Fleet 350/350/3.07 leaf rear. Last edited by 71Chev; 07-08-2004 at 10:07 AM. |
07-08-2004, 01:35 PM | #8 |
Has anyone used the S-10 seals on a Suburban? I need to do mine, but am not sure about using these ones since the Burbs have a 90 degree corner at the back of the door. But they could certainly be an improvement over the glue-on type.
'72 Chevy Suburban Custom Deluxe 10, 402/TH400 |
07-08-2004, 01:53 PM | #9 |
grebus1
I just took a small section and bent it into a 90 degree corner. It kinda pinches and makes a buldge in the corner, where it slips over the lip. I don't think I would use them like that on a burb, I think they will leak at the 90.
71 Chevy CST Long Fleet 350/350/3.07 leaf rear. |
07-08-2004, 05:11 PM | #10 |
sweet i love this board you guys are great!
07-08-2004, 05:38 PM | #11 |
Thanks 71Chev. Have you heard of anyone cutting the S-10 seals at 45 degrees at the corners (using some type of adhesive to bind the seal there)? I've been really disappointed with the stock seals, so I'd like to find an alternative.
07-08-2004, 07:09 PM | #12 |
No one I know has tried grebus1. It would be worth a shot, I thought about mentioning it. You might be able to make them work as is also, I don't know. You would need a flexible adhesive though. If you try be sure to let us know.
07-09-2004, 08:34 AM | #13 |
Thanks for the info. Back when I had my 84 S-10 I replaced my door seals with a set from JCWhitney. They were about $19 each and believe it or not fit well. You did have to shut the door a little harder due to being new. The next time I make it to the junkyard I will have to grab one off an S-10 and see how it does. I can probably get a good used set for under $5 for the yard I frequent.
FOUNDING MEMBER OF THE DRUM BRAKE CLUB Second Owner 70 C-10 Second Owner 93 GMC C1500 Third Owner 99 C2500 Crew Cab Short Bed |
07-09-2004, 02:35 PM | #14 |
71Chev, any chance of a pic of the corner from the other side of the door(the thick part of the seal)? Just trying to get an idea of how the seal behaves and looks when it is bent into the corner like that. Thanks in advance and for all the other info you have provided.
09-16-2004, 08:14 AM | #15 |
grebus1
Sorry, I lost track of this thread. I will take a picture of the outside at the miter and put it here later today.
09-16-2004, 09:09 AM | #16 |
great bit of info, thanks
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
09-16-2004, 07:04 PM | #17 |
Sorry for the delay.
09-17-2004, 12:03 AM | #18 |
Hey, no problem, thanks for posting that pic. It doesn't look like it bunches up at all in the corner. Think I might try these on my Burb even though they have more of a 90 degree corner at the back of the door.
