Help!! 3/4t To 1/2t Suspension
THIS IS KINDA NEW TO ME SO NEED HELP. THE REAR END ILL GET A DONOR FROM 71-72 BUT THE FRONT WHAT EXACTLY NEED TO BE DONE. IS THE ANY CHEAPER WAY FOR CONVERSION BESIDES THE KIT FOR $600. I DO WANT TO LOWER THE TRUCK A LITTLE.. 68 3/4T CHEVY
Fabricate till you "puke"
If you swap the lower a arms for 1/2 ton pcs,(71-72) you can go for the 1/2 ton balljoints , tierod assys (inners, outers, & sleeves), center link & bolt the spindles on for the 1/2 ton truck. the upper a arms will work, but note that the lowers have a larger hole for the balljoint on the 3/4 ton truck. You can also use the 73 up spindles(with corresponding balljoints, & outer tierod ends). As far as drop, you can cut 1 ring off the bottom of the front coils, for a 2 1/2-3" drop. aftermarket pcs (drop coils, spindles ect) are also wide open & fairly cheap on the 1/2 ton trucks best of luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
3/4t To 1/2t
Thanks Alot. That Helps Out So Much. :d
No trouble, I have done that swap & would be glad to help with any details that come up ....just "holler". crazyL
