Old 07-08-2004, 01:33 AM   #1
SWINGSAX68
Now the others dig........
SWINGSAX68's Avatar
68 upper a-arm shaft and shims????
When shimming the upper a arm shafts on a 68, are the shims supposed to mke the shaft line up parallel to the frame???? I think I have one of mine mising some shims....I just thaought about it right now.....
should the shafts be parralel to the frame???
thanks guys.
68 Chevy C10 Stepside Black Primer
78 GMC Longbed White
09 Chevy Silverado Shortbed Granite Blue
LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala
MEMBER OF THE DRUM BRAKE CLUB
Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX
Certified Music Educator
I hope Mom is up there watching and being my Guardian Angel
"I've got a fever.....and the only prescription.....IS MORE COW BELL"
-The Legendary: Bruce Dickenson
"F#$@ 'em up!!!!!!"
-The Legendary: Rogelio Escobar
TRUCKY LINKS
http://67-72chevytrucks.com/vboard/s...d.php?t=457750
http://67-72chevytrucks.com/vboard/s...d.php?t=461184
http://67-72chevytrucks.com/vboard/s...d.php?t=472848
http://67-72chevytrucks.com/vboard/s...d.php?t=417541
http://67-72chevytrucks.com/vboard/s...d.php?t=477788
SWINGSAX68 is offline   Reply With Quote
Old 07-08-2004, 05:48 PM   #2
COBALT
COBALT's Avatar
The number of shims depends on what the camber needs to be for the wheel to be aligned from top to bottom. A good guess is three shims per stud. Then you just let the alignment shop correct it. If you try to eyeball it you *might* come close, but when I did I didn't even get into the ballpark on the passenger wheel.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 07-11-2004, 11:23 AM   #3
tmcgrawlookalike
take it to alignment shop
tmcgrawlookalike is offline   Reply With Quote
