Old 07-09-2004, 12:42 AM   #1
Ridgeback
1972 K20 rolling chassis for sale
The frame has surface rust but no holes or rot and includes the following:
Dana 44 front axle (ratio appears to be 4:10)
Corporate(Eaton) rear axle (ratio appears to be 4:10)
9.50 X 16.5 tires with some tread and hold air
Manual steering gear
Engine and transfercase cross members
Brake and fuel lines
The chassis is located in central Virginia. If you are interested drop me an email through the Board and I will send you some pictures. Asking price is $500. Thanks.
Ridgeback
Ridgeback is offline   Reply With Quote
Old 07-09-2004, 03:50 PM   #2
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Seems Verry Fair, Don't Need It, Bump Ttt
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 07-09-2004, 05:09 PM   #3
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Hey Ridgeback I figured you had sold that frame by now...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 07-10-2004, 11:42 AM   #4
Ridgeback
Hi Chuck:
Thanks for the response. I have been overseas for quite a while and just got back for a month or so and then will be going back. I am just trying to clean things out before I go back.
Ridgeback
Old 07-11-2004, 10:21 AM   #5
72 CustomCamper
huh ???
I'd love to get that frame from you, I just don't have the $$$'s...
Chuck
Old 07-11-2004, 11:07 AM   #6
super-k
What`s the difference between a 8`PU and a Suburban frame?Swapable?I know there`s mount work,but I have`burban`s frame/mounts.Are wheel-bases the same?I don`t have`burb where I can measure.
72CheyenneSuperK20CustomCamper350/TH350,A/C 72SierreGrandeK2500350/TH350,A/C 72CustomDeluxeK20CustomCamperSB400/4SPD.A/C 72CustomC10SWB,TH400,project
super-k is offline   Reply With Quote
Old 07-12-2004, 01:49 AM   #7
ZOOMY
burb frames
The 67-72 burb frames are the same length. Same wheelbase. You'll have to change cab mounts & box mounts. Somebody here wil have them cheap.
ZOOMY is offline   Reply With Quote
