Old 07-09-2004, 01:41 PM   #1
barn9
Half a bubble off!
barn9's Avatar
Question Wiring info needed on '85 with 350.
A friend of mine has a problem with his '85, and it seems to be somewhere in the wiring. He found one wire that had rubbed on the frame (I think he said it was the frame anyway), and another that had been spliced (repair) by the P.O. and was corroded almost through. Fixed both of these and still nothing. When you try the ignition, it dims the headlights a little, so it seems like there is enough power, but nothing at the starter. I freely admit I'm not anything near an electrical whiz, but I told him I would ask on here to see if anyone had a wiring diagram or helpful info. Thanks in advance for any info, LB.
Just call me LB.
'71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads.
barn9 is offline   Reply With Quote
Old 07-09-2004, 10:10 PM   #2
a28doc
'87 V20 4x4
a28doc's Avatar
male sure you have a good ground from the battery to the frame esp if you have painted or coated the frame it may not be making a good ground that would be where I would start anyways hope this helps Doc
'86 K5 Blazer 4x4 FOR SALE
'87 v20 4X4
'99 S10 Blazer 4X4
a28doc is offline   Reply With Quote
