Old 07-10-2004, 02:03 PM   #1
aliencheyenne
700R into 73 C20
Just finished dropping the 700R into my 3/4 ton. Wanted to let those considering this swap know that my driveshaft was a perfect fit. No shortening and it has about 1" showing on the yoke. I was pleasantly surprised.
aliencheyenne is offline   Reply With Quote
Old 07-10-2004, 03:35 PM   #2
bluex
bluex's Avatar
What did you do for you linkage?? I can not get mine to go into L1. I'm still using the column linkage. I think I need to make the space on the column under the hood longer?
Paul
bluex is offline   Reply With Quote
Old 07-10-2004, 06:01 PM   #3
Jonboy
Slots go on anything!
I think that there is a detent in the column itself that will not let it get into 1st.
1974 Jimmy- 5.3/4L80e/NP241
Old 07-10-2004, 08:51 PM   #4
getfacsw
I have to agree, I don't think that you will ever get it into first unless you change the shifter.
I remember reading somewhere that any GM vehicle setup for three foward gears will not get low.
getfacsw is offline   Reply With Quote
Old 07-11-2004, 02:41 AM   #5
aliencheyenne
I went with a B&M truck floor shifter
Old 07-11-2004, 04:50 AM   #6
plumbcut
california fill
I have a 700 in my '77 truck. I can get into all gears including 1st, but it took some patience trying to adjust the linkage right. so- it can be done but it obviously wasnt designed for it.
pc
plumbcut is offline   Reply With Quote
Old 07-11-2004, 09:22 AM   #7
Greenlee
Greenlee's Avatar
Same here. I have a 700R4 in my 76 C-10 and it goes into all of the gears. It just looks a little out of wack because when in its in Drive the indicator on the column looks almost like its in the neutral position.
Greenlee is offline   Reply With Quote
