Old 07-12-2004, 09:19 AM   #1
CHEVYJEFF
CHEVYJEFF's Avatar
14 sf pb cable ???
Any one got a part # or truck model that I could use to get some parking brake cables that will work on my blazer to match the 14 bolt S.F. I swapped this in place of my old 10 bolt and the cables are too short. Thinking either a 454 SS that had a 14 SF or modifying the ones that came out of the 87 3/4 ton truck or if cables from a blazer w/ a 12 bolt would work.
http://members.cardomain.com/chevyjeff
57 2 DOOR HDTP
82 CORVETTE
90 V10 BLAZER
97 REGAL LSR 2100 (BOAT)
CHEVYJEFF is offline   Reply With Quote
Old 07-12-2004, 08:26 PM   #2
Bill W
How much shorter are your cables and why? I was under the impression that the brake set up on the 14 bolt SF was the same as the 10 or 12 bolt.
Bill W is offline   Reply With Quote
Old 07-12-2004, 08:52 PM   #3
CEDJUNIOR
The cables should work just fine. I swapped out a 10bolt for a 14SF and used the cables on my truck. They should be pretty tight though.
GM RPO Codes
'95 K1500 4x4 Ext Cab
5.7 TBI
NV4500 Tranny, 14 Bolt swapped in, locker, 3.73's
CEDJUNIOR is offline   Reply With Quote
Old 07-13-2004, 09:26 AM   #4
CHEVYJEFF
CHEVYJEFF's Avatar
the distance between the stopper end that fits into the outside face of the backing plate and the pressed on end that fits into the lever attached to the shoe is way too short, causing the pb brak to be extended to far out to even get the drum on. My cables are run in parallel to a bracket that joins them together. Thinking I may use a new longer inner cable and press on my stopper ends
57 2 DOOR HDTP
82 CORVETTE
90 V10 BLAZER
Old 07-20-2004, 08:47 PM   #5
1971 2wd
Yeah, I'm having the same problem. Mine is about 2-1/2" short on each side.
So heres a easy fix.
Just cut the bracket in half (the one that connects the 2 cables together) and weld in 2 strips of steel to your length.
It worked on mine.
72 blazer, 71 2wd short bed, 67 nova
Too many damn toys!!
1971 2wd is offline   Reply With Quote
Old 07-21-2004, 10:00 AM   #6
CHEVYJEFF
CHEVYJEFF's Avatar
you are talking about the u shaped tube looking thing that holds the front cable to the rear cable or the bracket that mounts to the frame
57 2 DOOR HDTP
82 CORVETTE
90 V10 BLAZER
Old 07-22-2004, 05:02 PM   #7
1971 2wd
The Cable to Cable thingy. (________) Looks like this, somewhat..
Yeah thats the part I'm talking about!!
