Old 07-12-2004, 12:22 PM   #1
PunkRock247
PunkRock247's Avatar
Question Gas Tank - EEC Question
I have a 1969 C-10 I am in the middle of building. I picked up a 72 gas tank with the EEC fittings on it cheap to replace the rusty mess I had. My question is can I just block the EEC fittings on the 72 tank because it is going in my 69? And if so is there any special gas cap I need to use or will any 72 gas cap work? Or should I just junk the 72 tank and look for another gas tank without the EEC mess?
Thanks in advance for any help.
1969 Chevrolet C-10 SWB
PunkRock247 is offline   Reply With Quote
Old 07-12-2004, 01:22 PM   #2
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
I had the same problem. The tank in my 70 had huge chunks of rust in it so I got a tank from a 72 at the junkyard. It was a tank with EEC, but I just put vacum caps over the EEC fittings, and I used a vented gas cap and I haven't had any problems.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 07-12-2004, 01:30 PM   #3
PunkRock247
Thanks Robert,
Did you have to specifically look for a vented cap or did you just use the cap from your original 70 gas tank?
Old 07-12-2004, 11:33 PM   #4
The tank I got was from a 1/2 ton (my truck's a 3/4) so I guess the filler neck opening was smaller and my original cap didn't fit, so I had to buy another. I had to buy a vented cap because that's the only way air can get out of the tank since I closed off all the EEC fittings.
RJD
Old 07-13-2004, 12:08 AM   #5
PunkRock247
Cool, thanks for the help. I will go out and find a vented cap. Thanks again.
