Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 07-12-2004, 02:02 PM   #1
67ChevyC10Stepside
67ChevyC10Stepside's Avatar
WTB dually axles and 10 bolt 4.10 gears (or close) for front and rear for step truck
i need a 3.73-4.10 gears for front and rear of a 87 step truck both axles are 10 bolt
and i need a dually setup that will fit a 85 GMC let me know what you guys have.
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon)
WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt.
67ChevyC10Stepside is offline   Reply With Quote
Old 07-12-2004, 09:18 PM   #2
BigBlockBurris
BigBlockBurris's Avatar
Dually rear
I got a complete dually rear. It is a Dana 70 out of a 87 chevy dually.
$400 complete with u-bolt plates and sway bar.
Located in Salisbury NC
BBB
BigBlockBurris is offline   Reply With Quote
Old 07-12-2004, 11:14 PM   #3
67ChevyC10Stepside
no way to get that to PA.
Old 07-15-2004, 09:13 AM   #4
LILREDGMC
Dually Rear
I also have a dually Dana 70, 4:10 ratio, open, from a mid eighties 1 ton plus van with a box on the rear. The dimensions, backing plate to backing plate, leaf spring perch to perch and overall are available. I thought I had them with me, but they are not in this notebook. Remember, this is a van dually and not a pickup dually. There are differences, which I don't know all of them. This axle has the leaf springs still attached. Asking $350. Did you ever decide on cabs for your early project?
Drop me an email if you want to inspect the rear.
LILREDGMC is offline   Reply With Quote
Old 07-15-2004, 10:08 AM   #5
LILREDGMC
Dimensions
Found the dimensions. May need to reconfirm for you. Backing plate to Backing plate - 54 3/4", Center leaf to Center leaf perch - 50", Outside wheel bead to outside wheel bead, of duals - 92". Hope this helps.
Old 07-15-2004, 12:51 PM   #6
67ChevyC10Stepside
havent really decided on a cab why? also im not sure how much he wants to spend on it.the 85 is my buddies dads the 87 is my buddies the 67 is mine and the 86 is my dads. the 85 we wanna make dually the 87 we need new gears or axles and my 67 has 4.11s so i wanna get an overdrive trans.
