Old 07-12-2004, 07:10 PM   #1
T HAUS
Front axle questions
72 Blazer front passenger bearings went out (bad).
I took the wheel off, took the lockout off. It was toast behind the lockout. I have not taken a 72 front end apart so I didn't know what to look for.
I then took the brake caliper off and the rotor came off with no problems. After doing some reading, I should of had to take some other stuff out before the rotor came off. There were barrel style bearings still inside the rotor/housing, but the pack itself was gone.
I've got the whole axle out now and the problem I'm having is I have one "gear" still hung on the end of the outer axle and I cannot get it off. There is no clip on the axle and I'm wondering if the outer teeth are twisted now.
Does anyone have a diagram or pic of an outer axle assembly so I can see what went where??
1966 Chevy C-10
1970 Chevy K-5 Blazer 4x4
1972 Chevy K-5 Blazer 4x4
2003 2500HD GMC Duramax/Allison 4x4 Full 4 Door
T HAUS is offline   Reply With Quote
Old 07-12-2004, 09:23 PM   #2
GM72K10
Next!
GM72K10's Avatar
Hope this helps!
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old 07-13-2004, 10:35 AM   #3
T HAUS
Thanks!!
That's perfect.
I need to find one of those high dollar manuals
1966 Chevy C-10
