Old 07-12-2004, 11:40 PM   #1
Johnny Outdoors
SOON TO BE A STEP SIDE
Johnny Outdoors's Avatar
help, vibration noise in 2nd and 3rd
i finally drove the truck today
yahoo
but there is a noise coming from the dash area near the floor -center
when the clutch is depressed while moving (coasting)
the noise goes away
it seems to be under load only
the ujoints are tight and not binding
there appears to be slop in the carrier bearing i can move the shaft all around inside the collar
how much slop is acceptable?
does anyone have any ideas?
all motor mounts and tranny mounts are good also
thanks in advance
67 CHEVY LONGBED----- BEST 51 DOLLARS EVER SPENT ON EBAY!
4.3 LITER INJECTED MOTOR WITH 5 SPEED GOING IN SOON
Johnny Outdoors is offline   Reply With Quote
Old 07-13-2004, 12:31 AM   #2
pissonNOS
senior member
pissonNOS's Avatar
could it be ur tranny?
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 07-13-2004, 12:40 AM   #3
Pushrod
Pushrod's Avatar
Could be your throw-out bearing if it is straight shift also. You should not have any slop play in your carrier bearing also.
___________________________
86 1/2 Ton Silverado
79 Chevy Long Bed
90 4x4 Short Bed
(2000 Ranger Ex-cab) Wifes
2001 Expedition - Toss-up
Pushrod is offline   Reply With Quote
Old 07-13-2004, 06:24 PM   #4
franko72
Franko72
franko72's Avatar
throw out bearing sounds right to me too.
1972 C20 cheyenne Super 402 BB/400 turbo LWB A/C Tilt, Cruise Control, Saddle tanks, Tach
My Home Page
Better to burn out than it is to rust
franko72 is offline   Reply With Quote
