this really bites...
so i start my truck up for the first time in a long time and i drive it down my driveway and turn it around in the street. i pull back in my drive way and feel some hard bumps or something i get otu and see this!!! the wheel is about to fall off.... only 1 lug is still on. one stud got sheared completely off and the rest jsut fell off...i dont know how this happened i know they were all tight when i put the wheel on last...im just glad i wasnt doing 30 or 40 miles an hour on the road!
so yeah i jacked it up and ptu on the spare bc these wheels are really difficult to get the lugs started on (and the mosquitos were really bad) and the tire was flat! so i had to put some air it in a grandma it back to the house
70 longbed 496/th400/Ford 9" |
i love summertime
HAHAHAHAHHAAHHAHAH, sorry man but that first pic is hilarious
1967 shortbox stepside Chevy, 365 hp 327, th400. GLOVE BOX LIGHTS FORSALE, click link for info http://67-72chevytrucks.com/vboard/s...d.php?t=273724 |
Member since 2000
hahaha @ 67cst
You must of tighten the lugs too much. Reason why that have torque spec when mounting wheel. If you tighten them to much you don't leave room for the stress the wheel incounters on turns. Wheels do flex, not surprising alot of people don't know this simple fact. Just so you know it happened to me already cause my jack-ass brother torqued the wheels at 100lbs. 75-80lbs is what the needed to be. it took less then an hour to get new studs, pound out the old ones and replace. Good luck. Last edited by Alexis; 07-13-2004 at 01:29 AM. |
When ever I have Bought new wheels, They have Always told me to torque the wheels to 100lbs. Maybe someone was trying to steal em and had loosened the lug nuts and was coming back later to get them. Hope you checked all the other wheels to make sure they are tight!
70short/step |
#5 | |
![]() Join Date: Aug 2001
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
![]() Join Date: Dec 2001
Looks like the studs are way too short.
1942 Master Deluxe 1969 C/10 1985 Blazer CUCV 1987 Jimmy 2004 Tahoe 2005 Silverado 1500 2005 Silverado 3500 |
#7 | |
A splendid one to behold
67 swb 02 wrx |
Pennyless Fool
Had this happen once years back when I let a friend/friends help out on a brake job.
Few hours, case a Bud, couple a more friends, lighter/wd-40 fights ![]() ![]() Never think its tight, any doubt at all, check it. Don't trust em less "YOU" check em. I agree with cdowns, those look like they might take shouldered nuts. Are the hole much larger than the studs?
"Who owns this car with the peace sign, the mag wheels, and four on the floor?" 67 Short Step 283/TH400/4.11 |
#10 | |
i nominate "DINNUT" as the posterboy for "WHEELS GONE BAD"
Embrace the Redneck
I work with tires day in and day out. 100 is what i have mine at and that is what The books reccomend. With alunimum i might go down to 80 or 90. but steel, 100 is good. Go to Harbor Freight or their web site and get a tork wrench (the kind that is adjustable and clicks) for about 20 bucks. same kind at the Zone is $75 - 120
my two pennies. sswj out
'01 Camaro Son, you just can't get there from here... |
oversize rims cause lots of stress on wheel studs especially the fronts do yourself a favor and change all the studs.you might also think about getting narrower wheels with less offset so this doesn't keep happening
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 07-13-2004 at 10:19 AM. |
#13 |
Not too old to learn
I agree with cddowns. The offset is way too much. The load of the truck is acting like a lever and needs to be closer to the center of the hub. This will also start to destroy your axle bearings.
1968 C10 a way to long restoration. |
#14 |
the more i look at your pictures the more it looks like you don't have the proper type of lug nuts either , does the manufacturer reccomend the use of special lugnuts??
#15 |
yeah im going to go to all 1 type of lugnut but havent had the opportunity to buy them yet. previous owner installed the wheels and tires and the lugs were not matching so im gonna go buy 24 lugs that much
#16 |
It looks to me like the lugnuts are fine, they are conical seat. It just looks like that there's just not enough thread engagement. You might also want to check the holes in the rim and make sure that they are not damaged. If they were previously, that may be a part of why this happened. Or...this might happen again if they were damaged this time. If there is any damaged at all, I would not recommend running them again!!
-Greg My Chevy trucks, past and present: 1962 C10 SB Fleetside 1964 C10 LB Fleetside BBW 1966 C10 SB Fleetside 1966 C10 SB Fleetside BBW 1968 C10 SB Fleetside 1971 C10 LB Fleetside 1971 C10 SB Fleetside 1972 C10 SB Fleetside Cheyenne 1972 C10 SB Fleetside Cheyenne Super 1972 C10 LB Fleetside Cheyenne Super 1974 C20 Cheyenne 1979 K5 Blazer Cheyenne 1982 K10 SB Fleetside Custom Deluxe 1982 K10 SB Fleetside Scottsdale 1986 C10 SB Fleetside Silverado 2008 Silverado 1500 4x4 |
#17 |
Oh, I forgot. Also, you might want to replace your wheel studs, the stress make have weakened them.
#18 |
just buying lugnuts that match isn't going to help, i'm quite sure that you need special shouldered nuts check with the manufacturer !! and replacing studs and lugnuts isn't going to help with the improper sizing issues that you have with this set of wheels !! you can maybe prolong the failure of the wheel studs awhile but don't expect it to go away!!! loosing a wheel at speed has very bad results
#19 |
i need to replace the wheel studs on the right front and back now... the back is missing 1 stud and the front is missing 1 and the rest are messed up and/or slightly bent... so im going to completely replace the front and just replace the 1 on the rear...
btw hows that first post for negative camber ![]() ![]()
70 longbed 496/th400/Ford 9" Last edited by dinnut; 07-13-2004 at 03:03 PM. |
#20 |
Franko72
Maybe your wife is trying to collect on your insurance policy. Just kidding
![]() 1972 C20 cheyenne Super 402 BB/400 turbo LWB A/C Tilt, Cruise Control, Saddle tanks, Tach My Home Page Better to burn out than it is to rust |
#21 |
Cantankerous Geezer
Can't tell from the pics, but those wheels look like they are made for larger diameter studs. Your truck has 7/16 studs, wheels are probably made for 1/2 or 9/16. I would replace the studs with 1/2" and get the proper lug nuts. Those little acorns aren't made for the aluminum rims.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
#22 |
The wheel studs cannot not be easily replaced with a different size. A person would have to drill out the drums/hubs and put in wheel studs that these vehicles did not come with. As far as the lug nut holes in the wheels...wheels only come in one size. Rather, they don't make wheels specific for 7/16 studs or 1/2 studs, etc. There are three different types of lug nut/wheel seat combos....conical seat (\__/), ball seat, (which has rounded edges- Honda, VW and BMW mainly use these) and mag style (aka; shank style). The lug nut in the picture is a conical seat lug nut. If the two mating surfaces (between the lug nut in the picture and the wheel) match, that style of lug nut will work fine. The picture of the wheel is not good enough to be able to tell what lug nut you need for sure but I would say that it looks like it uses mag style. If the holes on the wheel for the wheel studs are bigger than the studs (by quite a bit) AND the mating surface for the lug nut is flat, it probably needs the mag style. As far as the offset for the wheels, yes they are a bit too positive but not to the point where I wouldn't recommend running them. I think the problem here is one of three things; 1)the wheel studs are not long enough and the lug nuts are not getting proper thread engagement, 2)the lug nuts are not correct for the application, 3) the lug nuts were not tight to begin with or the mating surface for the wheel was damaged. I recommend replacing the wheel studs for the right front because of stress and any others on the truck that are missing or replace all of them if they are the same length as these were IF thread engagement is your problem (the wheel studs should at least be flush with the top of the lug nut). Not enough thread engagment would make perfect sense if you currently have mag style wheels and are using conical seat lug nuts, because the mag style wheels are a little bit fatter in that area.
-Greg My Chevy trucks, past and present: 1962 C10 SB Fleetside 1964 C10 LB Fleetside BBW 1966 C10 SB Fleetside 1966 C10 SB Fleetside BBW 1968 C10 SB Fleetside 1971 C10 LB Fleetside 1971 C10 SB Fleetside 1972 C10 SB Fleetside Cheyenne 1972 C10 SB Fleetside Cheyenne Super 1972 C10 LB Fleetside Cheyenne Super 1974 C20 Cheyenne 1979 K5 Blazer Cheyenne 1982 K10 SB Fleetside Custom Deluxe 1982 K10 SB Fleetside Scottsdale 1986 C10 SB Fleetside Silverado 2008 Silverado 1500 4x4 Last edited by silvertonguedevil; 07-14-2004 at 02:02 PM. |
#23 | |
Resident Curmudgeon
![]() Join Date: Dec 1999
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
#24 |
HEY that's a picture of the proper lugnuts!!!!
as far as the stud replacement the way i look at it if all 4wheels were on the truck improperly installed that means all 24studs were subjected to the same destructive stress levels and all 24 studs should be replaced ,or you can just replace a few now and wait to replace the others as the other wheels fall off
#25 |
Pennyless Fool
Here ya go, avatar sized.
