Old 07-13-2004, 04:41 PM   #1
rustyg
rustyg's Avatar
Inner axle shaft lengths?
Does anyone know the length from center of u-joint to end of splines on inner shaft's of a 71 k10 dana 44 . I deserve some sort of award for my actions, I threw all of my old axles out when I bought a set off ebay, turns out the new ones were for for closed knuckle. I'm trying to order a set from moser but I need dimensions, or perhaps a part number. Go easy on me.
71 k10 swb
72 k5
72 Burb 4x4
72 GMC Burb 4x4
rustyg is offline   Reply With Quote
Old 01-02-2008, 12:06 PM   #2
LVJimmy
Re: Inner axle shaft lengths?
Did you ever find the axle shaft length. I'm also having problems with my D44.
LVJimmy is offline   Reply With Quote
Old 01-02-2008, 01:27 PM   #3
msgross
msgross's Avatar
rustyg, where are you located? I think that I still have some shafts lying around in the garage. I do know that my corp 10 was different length than my dana44 shafts. The diff is not in the same location... I'll PM you my number... I live in Lebanon, PA.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 01-03-2008, 05:17 PM   #4
cobinder
Everything is work in progress
cobinder's Avatar
Get the number off your axle and go here and you can find exactly what inner axle you have.
http://www2.dana.com
You gotta dig but it's all here
Good luck with your truck!
How much?! It's just an old truck part!!
49 International on a 80 GMC 3/4ton 4x4 chassis
48 International KB-5 2 ton dump bed
04 Honda CRF "500"
09 Honda CRF450 fuel injected rocket
03 Suzuki hayabusa carbonfiber wheeled monster.
02 Ford diesel stretch van (toy hauler)
01 38' Monaco diesel pusher motorhome
cobinder is offline   Reply With Quote
Old 01-03-2008, 08:16 PM   #5
LVJimmy
I need the dimensions for axle shafts 904686-1 and 904686-2 neither one has dimensions listed. I do not have the original shafts and the other GM D44 shafts are to long.
Old 01-04-2008, 07:14 AM   #6
cobinder
cobinder's Avatar
Rusty, look on the bottom of page 76 (of the document) (82 of the pdf) and you'll see all the info your after
http://www2.dana.com/pdf/XGI.PDF
04 Honda CRF "500"
Old 01-04-2008, 03:53 PM   #7
msgross
msgross's Avatar
Im back in AL now so I am of no help... good luck
The Garage:
Old 01-04-2008, 04:54 PM   #8
1tonswb
1tonswb's Avatar
The warn catalog has the lenghts. If you didnt already find them Ill check for you tomorrow when Im at work.
1tonswb is offline   Reply With Quote
Old 01-04-2008, 07:46 PM   #9
'71c204x4454
'71k204x4454
The ones I have out of a dana 44 are short 18.5" and long 36.25". Hope that helps. (That first post sure is old).
1971 K20 4x4
1964 buick skylark convertible
'71c204x4454 is offline   Reply With Quote
