Old 07-13-2004, 05:49 PM   #1
jamie72
jamie72's Avatar
radiator core bushings thickness
could someone measure the correct 4x4 rubber bushings on there truck or blazer..i need the distance from the bottom of the core supprt to the frame.
or just the thickness of the upper bushing.
think i got the wrong set on the truck,the gap between the fender and the door is wider at the bottom..
thanks jamie
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 07-14-2004, 01:59 PM   #2
diggin69
Southern but in Ohio!!!!
diggin69's Avatar
they are about 1" thick
If you are replaceing them or already replaced them. look at it this way, the truck has probly been painted & those fenders have been adjusted before, maybe for the mushy bushings, might be able to adjust them back & tightend the fenders to re adjust them, 3 pennys put inbetween the fender & the door will give you about 1/4" of gap..... this might not be the case but its the first thing that popped in my head.
1969 C/10 3/4 ton 4x4 longbed custom, frame made from a 79
1972 custom-10 half/ton longbed
1980 1/2 ton 4x4 all original 350/350/205 with air
Eaton,Oh
rebelryder@hotmail.com
diggin69 is offline   Reply With Quote
Old 07-17-2004, 03:17 PM   #3
6869704X4
If you did replace them did you replace the cab bushings too?
I had to shim the front of my cab a little to cure the sane problem.
The more I learn about women, the more I love my truck.
6869704X4 is offline   Reply With Quote
