Old 07-13-2004, 07:34 PM   #1
westcasey
Exclamation 87 GMC A/C compressor
I was wondering how to check/refill the oil in my A/C compressor. It's acting like it might be starting to lock up and wanted to check/refill oil if possible and see if that helps. Any help would be greatly appreciated!!
1987 GMC 1500 5.7L
1985 Chevy 3/4 4X4
2001 Chevy 2500 HD 4X4
2007 Chevy 3500 Duramax 4X4
westcasey is offline   Reply With Quote
Old 07-14-2004, 07:43 PM   #2
westcasey
Unhappy No one can help me out?
No one can help me out??????
1987 GMC 1500 5.7L
1985 Chevy 3/4 4X4
Old 07-14-2004, 10:56 PM   #3
beaterC10
I don't think the oil in the refrigerent will fix the compressor problems. It is a small amount and is added when the refrigerent is put in. Is it possible the clutch on the compressor is going away?
beaterC10 is offline   Reply With Quote
Old 07-14-2004, 11:47 PM   #4
NeCrOmAnCeR
NeCrOmAnCeR's Avatar
You might want to hook up a set of gauges to check the pressures. The compressor does have a small ammount of initial fill, and the refrigerant in the system both help to lube the compressor . If you pull the compressor fill plug you will also loose your refrigerant charge. I suspect the erratic operation could be traced down to a compressor which is about to go or clutch problems like beaterC10 said. You could always put in an oil charge to see if it helps.
NeCrOmAnCeR is offline   Reply With Quote
Old 07-16-2004, 04:02 AM   #5
apstguy
LED King
apstguy's Avatar
The compressor has an initial 3oz. oil in it. There is no fill or drain plug so you have to open the system to air to do it.
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
