Old 07-14-2004, 01:47 AM   #1
71chevylongbed
Got Horsepower?
71chevylongbed's Avatar
motor mounts cracking
the motor mounts were replaces last august when i put in the new motor and it has about 11,000 miles on it now and the mounts are starting to split in the middle why are they doing this? should i be using polyurethane mounts instead of rubber mounts?
2001 Dodge 2500 Cummins, 4 inch lift, 35" Toyo MT's on Ultra wheels, P-Pump Conversion, AFE intake, Fass, 5 inch exhaust, Pyro,Boost,and Fuel pressure guages, and a whole bunch of other stuff "The Money Pit"
SOLD-71 Chevy C10 long bed- 2/4 drop-- 350,th400, Edelbrock performer RPM intake,Edelbrock 600 CFM carb,Crower 240 cam,port and polish,Dynomax headers,HEI ignition,dual 2.5 inch exhaust with Flowmaster 50 series mufflers
71chevylongbed is offline   Reply With Quote
Old 07-14-2004, 07:31 AM   #2
68C15
blood type; Retumbo
68C15's Avatar
any pics of mounts where they are cracking? sounds like a loose nut behind wheel. JK I used to have the same problem with a '80 K20 with Moroso solid mounts & over 500 # torque. I eased off the hot-rodding. what actually was happening is the frame was flexing too much under acceleration & the block wouldnt. something had to give. if that is your situation you migh try some poly mounts.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 07-14-2004, 04:48 PM   #3
71chevylongbed
Got Horsepower?
they are cracking in the middle where they bolt to the stands. i'm going to replace them with poly mounts when i pull the motor to paint and maybe i'll try to keep my right foot off the floor
