Old 07-14-2004, 04:50 PM   #1
71chevylongbed
Got Horsepower?
71chevylongbed's Avatar
brake lockup
when i apply the brakes more than once at low speed the right rear brake locks up what is causing it to do that? is it adjusted too tight?
2001 Dodge 2500 Cummins, 4 inch lift, 35" Toyo MT's on Ultra wheels, P-Pump Conversion, AFE intake, Fass, 5 inch exhaust, Pyro,Boost,and Fuel pressure guages, and a whole bunch of other stuff "The Money Pit"
SOLD-71 Chevy C10 long bed- 2/4 drop-- 350,th400, Edelbrock performer RPM intake,Edelbrock 600 CFM carb,Crower 240 cam,port and polish,Dynomax headers,HEI ignition,dual 2.5 inch exhaust with Flowmaster 50 series mufflers
71chevylongbed is offline   Reply With Quote
Old 07-14-2004, 04:52 PM   #2
gr8scott51
gr8scott51's Avatar
Wheel cylinder leak? Brake fluid on your shoes will cause the pad to "grab".
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
Old 07-14-2004, 05:01 PM   #3
damage
Like gr8scott51 said, either Brake fluid or the self adjustor is not working correctly. Every time you touch the pedal it could be tightening the brake. I had one do this once when doing about 65...shew what a ride!
damage is offline   Reply With Quote
Old 07-14-2004, 05:18 PM   #4
71chevylongbed
Got Horsepower?
i just pulled the drum and everything is clean and dry. it only locks up if i apply the brakes more than once at low speed less than 10 mph. at faster speeds i can brake hard and it dosen't lock up.
Old 07-14-2004, 06:35 PM   #5
71chevylongbed
Got Horsepower?
fixed it it was just adjusted way too tight
Old 07-15-2004, 07:58 AM   #6
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Just to toss another cause out there... Mine used to lock up one rear wheel after the brakes got heated up from driving and never when cold. I found the cause was a stuck emergency brake cable.
It was making the brake stay on just a little bit. This made the brake heat up and get sensative.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 07-16-2004, 10:27 AM   #7
BobM
A warped brake drum can cause lockup at low speed as well...Especially when wet.
BobM is offline   Reply With Quote
