Old 07-14-2004, 07:56 PM   #1
jorgensensc
jorgensensc's Avatar
Lowere Price!!!!! T-5 Tranny for sale!!! $300.00
I lowered the price on the tranny I have for sale. it came out out of a very good condition camaro with 53k miles. I really need to get this thing gone, and can help arrange shipping. Let me know!
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 07-14-2004, 11:03 PM   #2
67ChevyC10Stepside
67ChevyC10Stepside's Avatar
what are the specs on that? how many gears what all motors will it work behind? how much can i abuse it without it breakin?
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon)
WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt.
67ChevyC10Stepside is offline   Reply With Quote
Old 07-14-2004, 11:41 PM   #3
junkyardjohn
junkyardjohn's Avatar
WOULDN'T IT BE NICE IF WE COULD TELL THIS ABOUT TRANSMISSIONS???
IF YOU ABUSE ANYTHING IT IS GOING TO BREAK, SOONER OR LATER.
JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 07-15-2004, 12:01 AM   #4
jorgensensc
67chevyc10stepside,
This is a 5 speed tranny that came out of a 1995 camaro with 53k miles. I bought the 3.4 engine and 5 speed tranny together for an engine swap into a 1966 MG Midget, but only could use the engine. (I need a different tranny) I can't really tell you much about specs, but some tranny websights can. It comes with a V-6 60 degree eng bellhousing. If you want to change it over to a V-8 eng, you will need to get a 90 degree bellhousing, probably from a V8 truck or a 4.3 V-6. I was told the T-5 can hold up to a V-8 pretty well. If you want it to go behind a V-8 you will need to also get a different clutch as the V-6 is smaller and the shaft is a different spline count than a V-8 shaft ( I think the V-6 is 14 and the V-8 is 26 or 28, not sure though.). I am under the understanding that the clutch is fairly easy to find from a parts store or hot rod shop. It will be a clutch with a spline count of 14 (V-6 tranny) but the size for a V-8 clutch. I was told the internals on both trannies are the same, just slightly different gear ratios and spline differences.
Like Junkard said, I can't tell you how much abuse this tranny can take. I am definately not an expert. I do know they have put this same tranny behind fullsize trucks with V8's and Ford used them on their V8 Mustangs for a long time. I hope this helps a little. Let me know if you are interested.
Shawn
BTW: I took the intake apart on the engine and checked out the engine real good. It appears to be in Great shape, so I would assume the tranny would be in the same kind of shape since they both came out of the same car. But as with anything I haven't tested myself, i can't gaurantee that.
Old 07-15-2004, 06:32 PM   #5
TEXAS 68
Vortec in the works
TEXAS 68's Avatar
What happen to the shifter?
68? It's all figured out untill you get it apart.
Is it Sunday yet???
68 Project
68 SWB frame off/98 Vortec with stock FI/power everything.
95 ECLB 2500 with 346,000 on the clock(the original HD)
99 Lesabre-wifes ride
08 Crew Cab LTZ-All Mine
89 SWB 5/7 drop-Son's first ride.
TEXAS 68 is offline   Reply With Quote
Old 07-15-2004, 07:31 PM   #6
jorgensensc
The shifter was supposed to be part of the deal when I bought it from the engine/tranny distributor. When I got the engine and tranny the shifter as well as the slave cylinder were missing. I have been arguing with them for a month now about this and they say they don't supply those items, but said they would see if they could find one for me. I think I basically got blown off. Seeing as to how the shifter can be picked up from a junkyard for 20 bucks and a new slave is around 50 bucks, I decided to quit fighting the fight. I am taking a pretty large hit on the price I'm selling it for and it just isn't worth my time to continue to argue with them, or go out and find the replacement parts since I'm not going to use this tranny anymore. I think the price on the tranny is very fair, even without these extra parts.Besides, most people would replace the slave cylinder with a new one anyway. They are also 'helping me out' a little by letting me ship from their location, so I can get a better shipping rate for the buyer. Hope it's about as clear as mud now!
Shawn
Old 07-15-2004, 10:24 PM   #7
TEXAS 68
Vortec in the works
TEXAS 68's Avatar
I agree the price is very fair, wish Iwas further along to decide what I want to do.
Is it Sunday yet???
68 Project
Old 07-16-2004, 01:09 AM   #8
dinnut
dinnut's Avatar
how much do you think it would cost to convert over to a v8 setup... clutch, bellhousing, and all that... does nebody know?
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 07-16-2004, 02:05 AM   #9
jorgensensc
I think the bellhousing might be around 50.00. The slave cylinder would be around 50.00 new. I looked and it looks like it has the 26 spline input shaft. I will give you the pressure plate and the clutch plate that comes with it also, but I think you might need different ones for a v-8 flywheel. I would guess a good set new to be around 100.00, but I don't know for sure. Overall a very cheap setup for a good 5 speed.
Old 07-17-2004, 11:26 PM   #10
jorgensensc
Tranny has been sold! Thanks guys!
