Keep On Truckin'
Has anyone installed a gas door from a later model truck on the bed side between the rear tire and the front of the bed with the gas tank mounted between the frame rails in the rear? I'm not trying to make a show truck so I am looking more for convenience like the late model trucks.
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
It's a catastrophic success.
![]() Join Date: Jan 2003
drive shaft gets in the was of putting it in the frame below the bed but i was gonna do away with the floor anyway.
Opps I read it again, be a lot of plumbing to run it back, but I put a Koenig bed off a ford on a chevy and it had a good run as long as you can keep it going down hill it will flow
FUEL CELL GURU
mocwon,
I am working on your tank today (7/17). Do I need to move the filler to a new location on thre tank?? I haven't cut any holes in the tank for the filler. I will wait until I hear from you. Later, FCG |
#5 | |
Keep On Truckin'
Thanks, Greg
![]() Join Date: Dec 2002
I had the bedside doors filled when I had the truck painted.....removed both saddle tanks; cut off and filled the side pipe and moved the fill pipe to center front of tank... Welded into position at about a 45 degree angle... The fill pipes are in the wheel well ahead of the rear tires. And yes... I did clean the tanks thoroughly plus filling with water before any cutting or welding !!!.. I never did like the looks of the side doors.....
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal). |
