07-15-2004, 10:41 PM | #1 |
Vortec in the works
Tilt Again
search some old threads on ths but was wondering if column out of 92 van woukd work the same way.
68? It's all figured out untill you get it apart. Is it Sunday yet??? 68 Project 68 SWB frame off/98 Vortec with stock FI/power everything. 95 ECLB 2500 with 346,000 on the clock(the original HD) 99 Lesabre-wifes ride 08 Crew Cab LTZ-All Mine 89 SWB 5/7 drop-Son's first ride. |
07-15-2004, 10:59 PM | #2 |
Fabricate till you "puke"
D@mn, everytime somebody says "tilt", i get a "wooody" & start thinkin about the front clip....sorry , i cant help with your app. Take a look at my "tilt" http://community.webshots.com/user/hotrodhorn crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
07-15-2004, 11:02 PM | #3 |
Vortec in the works
looks good, I came across those pics when I searched for info.
07-15-2004, 11:30 PM | #4 |
Many thanks for the "thumbs up"....I have some real "pretty scars" from that old truck Been burnt pretty good from that old welder I am sure a few guys can help, but my old longhorn has a 4 spd column, that is shoved into the firewall about 2 1/2"(modified stock stuff). the sweetest ? comes up in traffic...Does that truck have a glass nose?....Nope, that is all steel best of luck, crazyL
07-16-2004, 11:45 AM | #5 | |
It's a catastrophic success.
07-16-2004, 02:10 PM | #6 |
Watch out for your cornhole !
92 van should be much different. They have the ignition switch on the column and I believe have wiper controls on the turn signal stalk. It's a lot bigger around overall (girth!?).
