Old 07-16-2004, 12:08 PM   #1
FirstGen
Just Don't Stop!
FirstGen's Avatar
WTB: 1ton 12 bolt yoke!!!
I need a 1 ton 12 bolt rear end yoke. this is where the u-joint seats on the rear end. if anyone has one for sale I would greatly appreciate it.
-Taylor
1968 C10 build in process
TT LSA/6L90e/9"
FirstGen is offline   Reply With Quote
Old 07-16-2004, 12:19 PM   #2
botboy
Will a yoke from an eaton HO72 work? I have a '67 C30 duallie I'm parting out and if the yoke will work I'd be happy to part with it for $30 shipped.
botboy is offline   Reply With Quote
Old 07-16-2004, 12:30 PM   #3
FirstGen
Just Don't Stop!
FirstGen's Avatar
humm, I'm really not sure. I'll find out. first off does it have 30 splines?
Thanks,
Taylor
TT LSA/6L90e/9"
Old 07-16-2004, 01:00 PM   #4
stelth2002
Young Gun wth Fast Inline
stelth2002's Avatar
I didnt know that the gm 12 bolt came in anything buy a 1/2 ton?
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!!
stelth2002 is offline   Reply With Quote
Old 07-16-2004, 02:36 PM   #5
botboy
I was kind of wondering about that too. I'll find out how many splines it has this evening. Does the cover on the rear of your differential have a ridge in it for the ring gear and no fill hole or is it completely rounded with a single hole for a square bolt to fill the differential with gear lube?
Old 07-16-2004, 03:01 PM   #6
Grim Reaper
It didn't
You need to state what ujoint size your looking for. There are three different sizes that will work on a 12 bolt including putting one on from a 10 bolt rear that uses a larger u-joint then any of the 12 bolts but has to go to a different seal AND there is a 4th off a 10bolt 3/4 ton front that might be even bigger and MIGHT work as well.
Grim-Reaper
70 Pontiac LeMans Sport Convertible, worlds longest resto in progress
Looking for 71-72 2wd Blazer or Jimmy Project
Grim Reaper is offline   Reply With Quote
Old 07-16-2004, 03:25 PM   #7
stelth2002
stelth2002's Avatar
If you need a yoke for a 1/2 ton 12 bolt, i have one that i will do 20 shipped to your door with the straps.
Old 07-16-2004, 04:05 PM   #8
FirstGen
Just Don't Stop!
FirstGen's Avatar
need the 1350 U-Joint size, maybe it is only aftermarket?
TT LSA/6L90e/9"
Old 07-16-2004, 04:08 PM   #9
FirstGen
Just Don't Stop!
FirstGen's Avatar
already have a 1/2 ton 12 bolt yoke.
TT LSA/6L90e/9"
Old 07-16-2004, 04:24 PM   #10
stelth2002
stelth2002's Avatar
Your thinking of everything, spicer sells an adapter that i would recommend if you plan on doing smokies.
Old 07-16-2004, 05:53 PM   #11
FirstGen
Just Don't Stop!
FirstGen's Avatar
how much are they?
TT LSA/6L90e/9"
