After doing this recently on my 71, I put together a small outline...
http://classicgmtrucks.proboards33.c...998112&start=0
FocuzTech Performance Evergreen Protective Coatings Gatorhyde...the best kept secret in spray in bed lining & protection |
Mike
Thanks Mike,I saved it to a folder for future use.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
Nice clean job and I too will keep this on file.
Designated A-hole!
It's on my hard drive. You might want to copy it to a thread in the FAQ section!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
Pics and schematic added.
Post Whore
![]() Join Date: Feb 2000
Nice writeup - I'm sure I have said this before but your engine is awesome looking! I'm using a 454 out of a 89 1 ton with it's alterntor - wonder how I could find out what it's amp rating is, I'm assuming it would be at least 100 amp.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
Mark, most likely your alternator is a 12SI 105 amp.
#8 | |
![]() And thanks for the compliment.
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Hey Mike,thanks for the credit at the bottom of your write up.Nice job.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
#10 | |
Anytime....thanks for your help.
well guys--I am starting phase II and found a cool fuse/relay/distribution box to tie everything together....http://classicgmtrucks.proboards33.c...998112&start=0
71 rustless in texas
You guys should check out www.madelectrical.com, I bought his CS12 rewire kit along with several other items. Mike spent about 45 mins. just B/Sing with me about my ideas when I ordered the stuff from him. He even threw in a couple of items for free.
Took me about 2 hrs to manufacture the harnesses and about 5 hrs to rewire the alternator and charging system. I also installed 40 amp headlight relays all where the external voltage regulator used to be. It's a sweeeeeet looking install, and works great.... |
