Old 07-16-2004, 10:41 PM   #1
BIG BOWTIE GUY
Angry Engine Miss
I Have A 97' 5.7 Lt. ,in A 2wd. ,short ,extended Cab Pick Up ,
When Traveling At Road Speed The Engine Has A Miss ,like A Plug That Is Fouled, If You Stand On It It Runs Perfect, Or Ideling It Seems Ok.i've Replaced Everything I Can Think Of..throws No Codes On The Computer..replaced:fuel Pump,filter,8-injectors, Egr Valve,cap,rotor,wires,plugs,o2 Sensors,t.p.i.,. And No Good.. Thanks Greg!!
BIG BOWTIE GUY is offline   Reply With Quote
Old 07-21-2004, 10:16 PM   #2
sbc350gearhead
sbc350gearhead's Avatar
Vacuum leak?
sbc350gearhead is offline   Reply With Quote
Old 07-26-2004, 01:09 PM   #3
fine89ck
I know I may have some objections to this, but take a look at the coil(s). My nephew had a 99 (blue oval vehicle), that idled good, but when lightly accelerating, it missed, very noticealby. He changed fuel pump/filter. A muffler shop, (that I wont mention), changed the computer, but the problem continued until someone recommened changing the coil. The coil was the problem. Hope this helps.
fine89ck is offline   Reply With Quote
Old 07-27-2004, 12:02 AM   #4
FXSTCHIEF
I have a 1998 Silverado Ext Cab w/5.7L and am experiencing similar symptoms. I usually get the miss or surging while in overdrive between 1400-1800 RPM's (40-50 mph). If I push on the accelerator or get out of that RPM range, it goes away, or at least I don't notice it. ?????? I was initially thinking fuel pump/pressure but it seems that may not be it by the responses. Tranny maybe???
FXSTCHIEF is offline   Reply With Quote
Old 07-27-2004, 02:18 AM   #5
99-2door
99-2door's Avatar
my 97 5.7L does that occasionally too. I have been wondering about this for some time.
95 K3500 SRW 5.7L Vortec 4L80e 4.10 G80
2001 GMC C3 6.0 AWD, Volant, 3/5 drop TBSS intake, HP tuners, pullies, 05 efans, 05 front brakes, etc.
2003 Tahoe Z71 Silverado front clip
99-2door is offline   Reply With Quote
Old 08-01-2004, 12:01 PM   #6
Rickracer
How many miles?
If you have over 65-70K, replace the plug wires and ignition coil. If it's less than that, look closely at the coil between the frame and the molded windings. If you see any white or burnt looking spots (very likely), replace it, and use the best one you can find. Nearly any "tuneup" I do these days includes a coil, based on experience.
Rickracer is offline   Reply With Quote
