Old 07-17-2004, 03:07 AM   #1
fordsux8269
need help on flip kit
i ordered the djm flip but all it came with was shock extenders bumpstops and a bracket i was wondering if i should send it back and get one that comes with spring plates u bolts saddles and everything else. also if you have any tips or pics of like a step by step for the install it would be great
fordsux8269 is offline   Reply With Quote
Old 07-17-2004, 12:14 PM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
That is all there is with a basic flip kit, You can get U-bolts from any bolt place or a diesel repair store should be able to get you some. You can use your current spring plate if you desire.
I do recommend getting a C-notch if you are flipping the axle, BUt....
instructions: Well, do you want to keep the brake lines attached, or keep the springs attached?
If you want to keep the brake lines attached you need to completely remove both springs and move them under the axle. If you want to keep the springs attached, you have to disconnect the brake lines and e-brake cables and the drive shaft and tires and lift it over the springs. This can be a pain if the bed is still on.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 07-25-2004, 02:39 PM   #3
fordsux8269
do i need to make new spring plates to go along with the u bolts and if so do yall have any dimensions for these and does any one have a c notch for sell
1982 chevy swb fleetside
Old 07-26-2004, 11:55 AM   #4
Captkaos
Captkaos's Avatar
Just use the plates that you currently have. The u-bolts only need to be longer.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
