Old 07-17-2004, 08:37 PM   #1
mneuen
Door panels... exterior mirror
Is there somewhere to find a step by step on how to remove the door panel so that I can mount a passenger side rear view mirror? I was thinking this was something I could do, but heh heh... not so much luck yet.
mneuen is offline   Reply With Quote
Old 07-17-2004, 08:38 PM   #2
mneuen
it might help to know that it is a 67 GMC...
Old 07-17-2004, 09:00 PM   #3
thisolechevy
first remove the arm rest, then remove the door handle and window crank (there is a little "c" clip on the back of the handles that there is a tool for to remove, although you might be able to do it with neelde nose pliers and a slotted screw driver) then remove the 4 screws on the bottom of the door panel and it should come right off.
Man I need another 67-72!!!
thisolechevy is offline   Reply With Quote
Old 07-17-2004, 09:45 PM   #4
mneuen
Thanks! I sort of got a little impatient and didn't put the nuts on the back and just screwed the three 5/16 screws into 9/32 holes that I drilled. Nice tight fit. One day, when I get adventurous, I'll put those nuts on back there.
