07-19-2004, 01:18 AM | #1 |
turbo enthusiast
lift kits
What do you have to do to a first gen blazer after you install a 9 or 10 inch suspension lift kit on it? Do the driveshafts have to be lengthened? The differentials cut and turned? Another board member has a 9 inch lift with 39 inch tires and I think that looks awesome! Any help would be appreciated.
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting " |
07-19-2004, 11:16 AM | #2 |
OBS guy
Pinion angles are going to be a MO-FO with a Blazer at those lift heights... Drivelines will need lengthening for sure... For that kind of lift, you are going to have to cut and turn the diffs to get a decent pinion angle.
6" is borderline, 8" is pushing it, and 10" is definitely going to take some work... Why not a 6" Suspension and 3" Body? That will get you 38's or 39's x 14-15" wide on a 12" rim... |
07-19-2004, 11:24 AM | #3 |
SKINNY TIRES RULE!
You could also go with some High angle Drivelines (http://highangledriveline.com/).
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
07-19-2004, 12:38 PM | #4 | |
The Blazer King
I have 6 inch suspention and 3 inch body. 38's barely fit if you like to offroad. they do rub alot. that is on a 10 inch wide wheel so any wider would be a big problem. If you want tires that big I would get 8 inch suspention and 2-3 inches of body. I really need 11 I think. That is with a true 38 though. If you buy a Ground Hawg, they run closer to 36 inches.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest. |
07-20-2004, 03:14 AM | #5 | |
turbo enthusiast
It was your truck that I saw. I love the look of it. That is how I would want mine to look. 6 inch suspension and 3 inch body is all you had to do? Thanks again for the help.
07-20-2004, 03:32 AM | #6 |
guess you fooled ^him^ 2wdblazer , hahahah
07-20-2004, 10:51 AM | #7 | |
The Blazer King
What???? Bad_turbo: My front driveshaft is VERY extended and I would recommend to get it made longer.
07-20-2004, 04:17 PM | #8 | |
it would seem BT thought you had a "9 or 10 inch suspension lift kit" cuz that's what he said he likes, then once ya posted he said its infact YOUR truck he saw that's sick! But yours is only a 6"(3body). - *ya fooled him* kinda
07-20-2004, 04:41 PM | #9 |
The Blazer King
ah ha. I see now.
