I just want the rear and front to sit level on a 73 C20 2wd. Are lowering blocks or drop shackles in the rear my best bet and are their kits out there for 14 bolt FF ? What about lifting the front end 2" or so ? Also, with the driveshaft setup on the truck, would I run into any pinion angle problems ? Thanks
#2 | |
I may be wrong here, but I would say you could either pull a leaf or two from the rear or Coil spacers, not the twist in's, get the spacer for the bottom of the coil. http://www.jcwhitney.com/autoparts/P...X/appId-385802 |
