Old 07-19-2004, 03:18 PM   #1
72SWB4X4
Florida Key's Member
72SWB4X4's Avatar
how do i start my truck without a key
i just dropped my keys in the water and got to a computer which wires do i jump to start the truck without a key...
haha laugh it may happen to you someday
Craig Wood
1972 SWB Chevy Cheyenne 4X4
Restored stock except 454 (481 cu. in. now)
most options Available
pictures of my truck http://myoldtruck.com/gallery/browse...500&userid=528
Come to florida and visit www.Paradisewatersports.com
72SWB4X4 is offline   Reply With Quote
Old 07-19-2004, 03:46 PM   #2
krue
Designated A-hole!
krue's Avatar
I don't know which ignition wires to jump, the only way I know to do it is run a hot wire to your coil, then use a screwdriver to jump from the positive cable on your starter solenoid to the post on the engine side of the solenoid. I don't know how easy that is to reach on a big block, but it's easy on a small block.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 07-19-2004, 03:55 PM   #3
Russell
Professional Grade
Russell's Avatar
If you know anything about the wiring, I'd guess you could probally go under the dash behind the ignition switch and do some jumping...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 07-19-2004, 03:58 PM   #4
67chevemall
67chevemall's Avatar
You can get it running by jumping the starter posts
BUT as for the sterring wheel lock you'll have to break it or smash the coloum and
un lock it there!
OR hopefully your wheel doesn't lock!
Cheers
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 07-19-2004, 03:59 PM   #5
53burb
53burb's Avatar
You need to run power to the distributor. If it is an HEI (electronic) ignition, then u can run it directly from the battery. If it is points, then you will have to run power to upstream of the ballast resistor. You will then have to jumper the leads on starter solenoid temporarily until it starts. You have to jumper the main lead from the battery, and the "s" terminal on the solenoid. Thiis will work temporarily, do not forget to remove power from the distributor when u r home...
53burb is offline   Reply With Quote
Old 07-19-2004, 04:26 PM   #6
thisolechevy
if its the stock engine or atleast the stock wiring on teh back of your ignition switch there is a plug, unplug it and you will have about 5 or 6 different colored wires going into it. connect the PURPLE to the BROWN and your starter will engage and it should crank up!! just be careful thats alot of power going throught the wires. I would get a new lock cylinder IMMEDIATLY to solve your problem.
Man I need another 67-72!!!
thisolechevy is offline   Reply With Quote
Old 07-19-2004, 05:01 PM   #7
2wdBlazer
The Blazer King
2wdBlazer's Avatar
Alot of these older key holes are real sloppy. A small screwdriver stuck in there may work like a key or even try another GM key. Sometimes they work.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 07-19-2004, 05:17 PM   #8
toddtheodd
The oddest Todd around
toddtheodd's Avatar
"or even try another GM key"
I work in the food distribution industry, and when I helped in transportion I ran into the problem of our truck drivers constantly trying to take the key of the truck they want. Well, when a driver comes in that needs a sleeper, and that's the only sleeper on the yard, we have to get it started somehow. I became very adept at "jiggling" a key. If you play with it right, you can start anything with a "similar" key. I've even started one with a padlock key.
toddtheodd is offline   Reply With Quote
Old 07-19-2004, 10:55 PM   #9
atcavage
Maybe I'm a little late, but I've found that a screwdriver in the ignition can work, especially on older ignitions. Push starting is always and option.
1972 1/2 ton Chevy C10 V-8 350, crate engine, with Flomaster dual exhaust. She's Old Blue the Truckinator (no relation to Arnold )
atcavage is offline   Reply With Quote
Old 07-19-2004, 11:12 PM   #10
tom hand
CCRider
tom hand's Avatar
If wiring not your thing....just run by a parts store and buy a new ignition switch....unplug the wires from the old and plug it into the new...turn it with a screwdriver because when you buy just the switch, it won't have the lock cylinder...by the way thats how easy it is to steal one of these trucks...so install some kind of thieft prevention when you get it home
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 07-20-2004, 05:26 AM   #11
GMCPaul
Whew thankfully he called us after reading a few of these directions. In the future if any of you lose your key you take a short 2" wire and stick one end in large red wire terminal on back of ignition switch and other end in the large pink wire terminal, this gives power to the trucks electrical system to supply power for points or HEI Distributor, then you take a second wire from large red wire on back of the ignition switch and touch it to the purple wire which begins cranking the motor over as soon as motor starts remove the 2nd wire to disengage the starter.
You can use a screwdriver at starter to crank motor over to start also instead of using a second wire. You guys would have had him scavenging all over several, several feet of wire and then a few had the wrong wires posted to start the truck and keep it running.
So Red to pink for power, red to purple to crank motor over.
GMCPaul
GMCPaul is offline   Reply With Quote
Old 07-20-2004, 09:08 AM   #12
krazy_texan
krazy_texan's Avatar
yeah, what Gmc Paul said
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 07-20-2004, 09:44 AM   #13
jorgensensc
jorgensensc's Avatar
And if you don't have the pigtail on the back of the ignition switch, and only spade connectors, be sure to put the wires back on the correct posts. I hotwired my truck once when I left my keys out of state and flew back home, only to find I couldn't get in my truck. Thankfully I got in and hotwired it, pretty easy, but when I got the keys and tried to put it all back correctly I got the wires put on the ignition switch wrong. The previous owner had a company put a new wiring harness under the dash and they wired 2 wires backwards. I played hell trying to get the thing running until I figured it out.so uch for wiring diagrams
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 07-20-2004, 04:00 PM   #14
BtnkBndt
Pennyless Fool
BtnkBndt's Avatar
Maybe I should print this and post it on the truck.
"Who owns this car with the peace sign, the mag wheels, and four on the floor?"
67 Short Step
283/TH400/4.11
BtnkBndt is offline   Reply With Quote
