Old 07-19-2004, 06:51 PM   #1
FuelCellGuy
FUEL CELL GURU
FuelCellGuy's Avatar
Need rearend for 4WD to 2WD conversion....
Anyone have a 71-72 GMC five-lug rear?? I just think this should be a swap-in for a leaf sprung 4WD rear. Will a 73-up rear fit?? Later, FCG
FuelCellGuy is offline   Reply With Quote
Old 07-19-2004, 07:42 PM   #2
my new 72
faster, faster, faster
my new 72's Avatar
Hey FCG, you better check local inspection laws about converting a 4wd to a 2wd. A converted rig is illegal to inspect here in Texas.
I'm going to Law School, wanna debate? It's good practice.
my new 72 is offline   Reply With Quote
Old 07-19-2004, 08:02 PM   #3
JimKshortstep4x4
Smile
A 2wd leaf spring has the spring perches in a different location than the 4 wd spring perches.
Jim
Old 07-19-2004, 08:15 PM   #4
FuelCellGuy
FUEL CELL GURU
I am not worried about the inspection as when it is registered as an antique, no inspection is required. Jim, are you sure?? Are they wider or narrower?? I am confused.
Old 07-19-2004, 08:54 PM   #5
smonty
Smonty
Hey Mark,
If you need one with a higher gear ratio I have a good 2wd leaf spring axle off a 72 GMC. If you find out you can use it we can work something out towards what I owe you for the wheels.
Ernie
72 2WD Blazer
68 SWB Fleetside
67 SWB Stepside
2005 Chevy 1500HD Crewcab
56 Chris Craft Mahogany Runabout
Looking for 36 Chevy 1/2 Ton P/U Project
smonty is offline   Reply With Quote
Old 07-19-2004, 10:12 PM   #6
FuelCellGuy
FUEL CELL GURU
Ernie,
Can you measure outside to outside on the spring perches?? Is it 5-lug?? Later, Mark
Old 07-21-2004, 11:30 PM   #7
FuelCellGuy
FUEL CELL GURU
TTT...anyone have the measurements outside to outside spring perch on a 2WD leaf spring rear???
Old 07-22-2004, 12:14 AM   #8
smonty
Smonty
Hello Mark,
I will get you the measurements on my GMC 2wd tomorrow.
Ernie
72 2WD Blazer
68 SWB Fleetside
67 SWB Stepside
Old 07-22-2004, 12:53 AM   #9
jose
jose's Avatar
FuelCellGuy Measurement from outside to outside of perches for two wheel drive with leaf springs from a 72 GMC is 44 1/4 inches . Jose
68 GMC 4x4 SWB
jose6772@yahoo.com
jose is offline   Reply With Quote
