67-72 Empty Truck Wieght
I was reading a post where someone stated the wieght of there rig with them in it and i was wondering if anyone else has wieghed thier truck?
Mine is a 72 SWB C10 It weighs 3660 Empty No spare or anything |
![]() Join Date: Jun 2003
My 72 C-20 longbed with the C-10 springs weighs 4500 lbs. with the spare in the back. The bed is coated with a spray-on liner as is the underside of the cab and the inside of the hood and the front fender wells top and bottom. I think it adds alot of weight.
72longbed ![]() ![]() ![]() ![]() |
My C/20 weighs in at 5000lbs with the spare and a full tank of gas.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
71 Chevy 1/2 4500 lbs. 71 GMC 3/4 5500 lbs. Both are long beds, 402 w/air
Insert funny comment.
![]() Join Date: Dec 1999
Wow, some heavy trucks! Im hoping a short step is under 4000... maybe Im off. Time to beef up the motor.
------------ - Mark -My Build Thread... -68 C10, LT1 - Undergoing Frame off resto -86 IROC-Z T72 turbo 355, M6 -70 Camaro http://www.iroc-ss.com |
Fabricate till you "puke"
My Longhorn scales right @ 4040, empty with about 1/2 tank of fuel.....the old truck is pretty stripped, & runs 1/2 ton suspension tho. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
My '69 C-10 SWB fleetside w/350 & 3-on-the-tree weighed around 3500 at the city dump scale a few years ago. No spare, dual exhaust, fuel level unknown, & a few square inches of cowl/firewall rusted away.
![]() Join Date: Mar 2003
71 C-20 2 people in it with a stepside bed and 1/2 tank of fuel came in over the scales at 4250. Small block with a T-350
According to my Funk & Wagnal of trucks....
1/2 Ton Step-Side should weigh approx 3426 production around 22,042
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
20' Daredevil (Ret)
![]() Join Date: May 2003
LWB K20 with spare tire and who knows how much fuel, 5300#.
My short step with 350/350 and a full tank of gas (21 gallons) came in at 3800 with no spare. Mine also has a wood bed, but I don't know if that adds more or less weight.
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
The Blazer King
I wish somebody would get a top-less 2wd Blazer to the scales. I bet those are the lightest.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest. |
#13 |
1969 Custom 30 wrecker
1969 C-10 short stepside. Empty with spare weighed 3700 at the scrapyard scale.
Mine has an 1/8" stainless steel bed floor and 350/350 running gear.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
#14 | |
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears 1948 Chevy FleetMaster Coupe, LS1, (almost done) 1950 Chevy StyleLine Coupe 250/6 3x2 Dueces 2009 Toyota Tundra 1996 Harley RoadKing "I maybe getting old, but I can still burn rubber with the best of them" |
