Old 07-19-2004, 10:29 PM   #1
Staceydude
Staceydude's Avatar
Anyone know what years instrument clusters will fit an 81 Blazer???
I need a new Instrument Cluster for my Blazer.
Mike on the board here has one out of a 78 and one out of a 87, which one may fit my 81 Blazer???
Which one will be a plug in play?
Please answer.
Regards,
Stace
Staceydude is offline   Reply With Quote
Old 07-19-2004, 10:39 PM   #2
Russell
Professional Grade
Russell's Avatar
If the 78 has an electric oil pressure gauge, and all the same idiot lights / gauges are your pod -- It'll be a plug n' play setup, the 87 will also be a plug an play setup.
Check the Tach info thats found in the Interior part of the Garage section of 73-87.com (woah, that was a bit of a mouthful, ) It'll have all the info you need, incase I am wrong (I'm fairly sure I'm right though!)
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 07-20-2004, 07:35 AM   #3
Staceydude
Staceydude's Avatar
Thanks Russell
I appreciate the help.
Stacey
