Old 07-20-2004, 09:55 AM   #1
jorgensensc
jorgensensc's Avatar
Dumb question about painting an engine?
Kinda a dumb question, but here it is:
I noticed alot of guys and engine builders put a block together with pan, timing cover,heads, and even the fuel pump then paint the whole thing one color. Does doing this help seal the motor and all the gasket interfaces? I only ask because I personall like it when the block is one color (maybe orange), the heads a different color (maybe black), timing cover, etc.
I am not putting anyones work down at all, I'm just curious as to the thought process or tecknique being used if any. Or is it just easier and that is why builders do it?
Thanks and I hope no one takes offense to this thread if your engine looks like this, because mine does too, but it drives me crazy.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
