Old 07-20-2004, 07:50 PM   #1
5150
C10 Club Tennessee
5150's Avatar
4 inch drop?
I am dropping the rear of my truck 4 inches with coils. I have heard different opinions but I want you guys opinions. Can I just put the coils in or do I need a panhard bar and new shock mounts?
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 07-20-2004, 11:27 PM   #2
ShamrockCustoms
Project56 on hold
ShamrockCustoms's Avatar
4" will require either new shock mounts of shorter shocks. ( you want 60% rod showing when at ride height)
you may be ok with the panhard , but it would be best to check to see if its parallel with the ground and how far it has travleled from that position. at 6" you would definitely need the change. good luck!
Shamrock Customs
Forever-in-the-Future Custom Shop
2009 Mitsubishi Lancer GTS daily driver
1956 Chevy Stepside rodstoration on winter hold
ShamrockCustoms is offline   Reply With Quote
Old 07-21-2004, 12:10 AM   #3
5150
C10 Club Tennessee
5150's Avatar
How much shorter shocks? What application can I ask for that will fit my 70 stepside?
Bryan
Bryan
www.gmtruckshow.com
Old 07-24-2004, 03:51 AM   #4
GMCPaul
Shock relocators will give a better ride than just using a shorter shock, at 4" drop the shock is at to flat a angle with the ground to perform as designed and the shock relocators allows them to be at the proper angle to function correctly. In regards to needing the adjustable track arm bar you are right on the borderline, the only way to know positivly is install the rear 4" springs on truck with all of body installed so full weight is on suspension then measure the rearend to see if its centered, I find 70% of the time or more that the adjustable bar is required to center rearend properly under the frame on a 4" rear drop. You'll find everything you need here
http://www.gmcpauls.com/lowering_springs_&_parts.htm
GMCPaul
GMCPaul is offline   Reply With Quote
