Old 07-20-2004, 08:38 PM   #1
smitty62
smitty62's Avatar
Question Headlight wiring?
Anyone have a wiring diagram for the under hood wiring for an '84 they can post or e-mail? My low beam headlights quit on me.
Stepsides look like real trucks!
Smitty
smitty62 is offline   Reply With Quote
Old 07-21-2004, 12:46 PM   #2
crackajacka
Stylin
crackajacka's Avatar
if i can find it. its easy to figure it out, cause everythings just kinda jumped off the prongs . make sure the connection to the lights are makeing a good connection mine would go out if i hit a bump and didnt have the plug in the right spot, also inspect the wires going to your low beam headlights. mine run from the fuse block and there are i think 5-6 wires the brown wire goes the proportioning valve i belive. but if i find my hand drawing of it i will look. or if i can find my shop manual wire diagram book
Ive been traveling for some time, with my fishin pole and my bottle of shyne.
Most Girls like finished products and just dont understand what a good addiction does for you
http://www.paulwall.us/
crackajacka is offline   Reply With Quote
Old 07-21-2004, 01:12 PM   #3
crackajacka
Stylin
ok im gona put where the wires go to what plug they go to aka driverside high beam black ,dark green.. on the 3 wire plugs the middle color will be the middle wire on the plug
rt side marker, brown-dark blue
rt high/lowbeam, tan-light green-black
rt park/directional lamp, dark blue-brown-black
rt high beam, light green-black
1 ground to core support
left high beam, light green-black
left park/directional, light blue-brown-black
left high/low beam, tan-light green-black
left side marker, brown-light blue
Old 07-21-2004, 02:45 PM   #4
apstguy
LED King
apstguy's Avatar
Usually if the headlights die on you it is either the switch or the low/high beam selector switch.
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
