Old 07-20-2004, 10:42 PM   #1
76bonanza
76bonanza's Avatar
Tire size
I am running 32-11.5 now I think my truck is stock height can I run 33-12.5 with no rubing?
Also how much hieght will it add and how much wider or further out will they stick?
I dont want them to hang out of the wheel wells much more than they do now.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 07-20-2004, 11:14 PM   #2
stan79chevy
stan79chevy's Avatar
i had to do a little fender trimming
to get 33x12.5 to fit on mine. i allready had rust there so it just cleaned it up a little.
79 chevy k20 350/350/205/D44/14bFF
4.56 gears rock
LWB pimer black
01 S-10 ZR2 extended cab
4.3/4L60E/233
3.73 gear 31" DICK CEPEK CRUSHERS
stan79chevy is offline   Reply With Quote
Old 07-25-2004, 02:01 PM   #3
fanman
I'm running a set of 33x12.5's on stock rims on my 77 3/4ton. I still have a lot of clearance, and I'm at stock height. Mine don't stick out from the fenders at all. You might gain a half inch of height.
"When I start my car in the morning I want the neighbors to think the world is comming to an end." Homer Simpson
I'm not stuck, I've still got some gas left"
fanman is offline   Reply With Quote
Old 07-25-2004, 07:33 PM   #4
1972Supercheyenne4wd
Have another!!
I had 33x12.50's on my 74 with stock height at first till i buckled my fender molding in from trying to climb a hill. I then added a 4" lift, it sat pretty then. Usualy chevy axles set deep in the wheel wells anyway, so you'll be fine with 8" or 10" " rims, but if you go with 12" or better rims then you'll be looking at tires sticking out.
1972Supercheyenne4wd is offline   Reply With Quote
